Power formula for space navigation, MHD propulsion
2 replies · 419 views
soliris
TL;DR
Power = budi
Extended power formula for space navigation with MHD propulsion, considering that planet Earth owns such an engine..
Hello
Interested in MHD propulsion, I thought this power formula in watts, inspired by the Lorentz force, might be useful:
P = B.U.D.I,
where B = Tesla magnetic field, U = rotational speed, D = diameter of a rotating magnet, and I = intensity of the injected electric current.
The model used here, I admit, is that of planet Earth, which seems to possess such an internal engine!
What do you think?
While MHD may be important for ionic particles suspended in the atmosphere, the Earth's magnetic field is probably insufficient to keep a juggler's balls in the air.
What were you thinking of navigating through space ?
The Earth's magnetic field might be distorted by the object's mass.
Hehe, the juggler's balls..
You're absolutely right about the outer magnetosphere: the surface field is indeed minuscule (~50 microteslas). But it's different in the ferrous core, where the Earth's thermal and magnetic engine originates, isn't it?
Actually, I was thinking more about the Earth's depths, because my formula is inspired by geodynamo models in the liquid outer core, where Lorentz forces (F = I × L × B) coupled with convection currents generate the Earth's magnetic field. So, to answer your question about space navigation: no, I don't intend to use the Earth's field as a point of leverage! The Earth analogy simply came from the idea of a moving conducting fluid." under the influence of magnetic and electric forces.
I envision instead an MHD thruster carrying its own high-temperature superconducting magnet to generate a very intense local magnetic field (B).
(I previously subjected this formula to a rigorous dimensional analysis -taking U as the linear velocity at the rotor's extremities-. The product does indeed yield Watts. Obviously, this doesn't presuppose geometric coefficients (the π factors, the flux orientation, etc.) or Joule effect losses.
You mention the distortion of the field by the object's mass; regarding the formula P = B ⋅ U ⋅ D ⋅ I, if we apply it to a closed propulsion system (such as an MHD submarine or an autonomous space propulsion system with its own magnet), are you referring to a magnetic shielding effect or a specific magnetohydrodynamic interaction within the space plasma?
