Power generated by this current source
Guillem_dlc
In the circuit of the figure knowing that ##V_0=10\, \textrm{V}## determine ##V_S## and the power generated by the source ##J##.
Sol: ##V_S=-4\, \textrm{V}##, ##P_J=60\, \textrm{W}##
Kirchoff law
Figure:
Circuit schematic with a dependent current source labeled 2 I0 and voltage Vs on the left, a 2 Ω resistor on top, a 8 V source with current I0, a 2 A current source, a current source labeled J, a voltage Vx, and a 6 V source on the right.
My attempt at a solution:
Handwritten circuit schematic with a dependent current source 2Io on the left, a 2 ohm resistor carrying current J, a 8V voltage source, a 2A current source, a J current source and a 6V voltage source, with labelled currents Io, 2Io and J and voltages Vs and Vo.
1st kirchoff law:
$$J=2I_0+I_0=6\, \textrm{A}$$
Hand-drawn circuit schematic with nodes labelled V1, Vj and a 6 V reference node at the bottom; contains a dependent current source 2Io, a 2 ohm resistor, a current source J, 8 V and 6 V sources, a 2 A source, and voltages Vs and Vo marked.
$$V_1+8=10\rightarrow \boxed{V_1=2}$$
$$V_1=6-V_S\rightarrow \boxed{V_S=-4\, \textrm{V}}$$
We are looking for ##P## generated in ##J##
$$V_J=V_1-2\cdot J=2-2\cdot 6=-10\, \textrm{V}$$
Hand-drawn circuit schematic of a current source J with a green arrow and + and - signs, between nodes labelled V_J and 0; a green arrow below the source is labelled J.
$$\boxed{P_{\textrm{gen}}=(V_J-0)J=-10\cdot 6=-60\, \textrm{W}}$$
Wouldn't this exercise do like this? I have tried it but the power is negative.
  • Hand-drawn circuit schematic with a dependent current source Io labeled Vs on the left, a 2 ohm resistor carrying 2A on top, a 8V source, a 2A current source, a J current source, a 6V source, and nodes labeled Vs, Vs+8, Vo and V1, with Ref at the bottom.
  • Circuit schematic of a current source labelled J with an arrow pointing right inside its circle; node V_J on the left and -6 V on the right, with a green arrow and + and - signs marked below the source.
Your ##V_1=6-V_S## should be ##V_1=6+V_S##, but it looks like that was just a typo.
The rest looks right. I would not rule out the possibility that the answer is negative.
Is it negative?
Guillem_dlc said:
Is it negative?
As I wrote, your working looks fine, apart from that typo. So unless I am missing something the answer is negative.
