Power needed to climb constant slope at constant speed
The discussion revolves around calculating the power required to climb a constant slope at a constant speed, focusing on the relationship between power, weight, and gradient. Participants explore theoretical and practical aspects of this problem, including assumptions of efficiency and unit conversions.
  • One participant seeks a simple method to calculate power needed for climbing hills, emphasizing the need for basic calculations without complex algebra.
  • Another participant explains that power depends on efficiency and provides a formula for calculating power based on weight, height, and speed, assuming perfect efficiency.
  • There is a discussion about the importance of using consistent units, with one participant expressing confusion over the units of weight and mass.
  • Several participants attempt calculations using different values for weight, speed, and angle of incline, leading to varying results and some corrections regarding unit conversions.
  • One participant highlights the difference between weight and mass, clarifying the formula for power as P = mgv sin(θ), where g is the acceleration due to gravity.
  • Another participant shares a calculation related to aircraft climb performance, discussing the power required for an aircraft to climb and questioning the implications of their results.
  • Further calculations are presented, with participants correcting each other's unit usage and assumptions, particularly regarding the sine of the angle of incline.
  • A participant raises a question about the rate of change of power with climb, suggesting that vehicles require more power as they ascend and inquiring about a formula to quantify this relationship.
Participants express varying levels of understanding and agreement on the calculations and concepts involved. There is no consensus on the final results, with multiple competing views and corrections being made throughout the discussion.
Limitations include assumptions of perfect efficiency, the need for consistent units, and the potential for confusion regarding the definitions of weight and mass. Some calculations rely on approximations and may not account for all variables affecting power requirements.
daveyjones97
i failed science at school and often want answers to q's thank God for pf!
i want a nice easy way to work out how much power you would need to climb hills: power versus weight and gradient is what I am after. assume constant speed constant gradient ignore wind resistance. I am after simple ball park calculations. nothing I've seen so far is quite what I am after and I am not too hot on algebra.
any answers in terms a 5 year old would understand please.
It depends on how efficient your mode of transportation is (your legs, bicycle, truck) on a certain surface (wet, sandy, dry). Assuming perfect efficiency, all you have to do is overcome gravity. If your weight is w, and the hill has a height of h, then it will take a total amount of energy wh to reach the top of the hill. The rate at which you expend energy to reach the top, or the power, depends on the time you take. If you go on a windy trail, it takes less power but a longer time so you expend the same energy in the end. The power would be
P = wh/t
where t is the total time to reach the top. Let's say you don't know the time it takes you, but you know your average speed v and the length of the trail to the top x, then from v = x/t, the power needed becomes:P = whv/x
Let's say you don't know the height of the hill, but do know the average steepness of the trail, measured as an angle θ in degrees from a flat trail. From sin(θ) = h/x we have:
P = wv sin(θ)
where P is the power required (or energy expended per second), w is your weight (not to be confused with mass), v is your total average speed, and θ is the angle of your path with respect to the flat ground. Again, this equation assumes that your system is perfectly efficient (no internal losses, or loss to friction), and you are able to maintain a constant speed v.
im fine with assuming 100% efficiency, so 130kg x 16kph x 20 degrees = power? 41600, joules? i swear I am not deliberately being dumb! I am the poster boy for those who spent school looking out the window only to need to relearn it all later in life. if I am right the end result is in joules?
For instance, if you weigh 200 pounds (in SI units that is w = 890 kg m/s2) and the road inclination angle is θ = 10°, then:
power in Joules/second = 154 times the speed in meters/second
You have to make sure you have everything in the same units system.
i apologise for having such a base level of knowledge, luckily i have the sense to use the same measurement system, and to check that if i get a silly result. 200 pounds is 90.7kg and m/s squared i thought was acceleration. in an effort to help myself I am looking for just a constant speed so don't understand 890kg m/s unless that's a watt hours alternative/equivalent measure?
Weight and mass are not the same thing. Weight is mass times the acceleration due to gravity: w = mg. Pounds is a measurement of weight, whereas kilograms is a measure of mass. Let me rewrite the equation:
P = mgv sin(θ)
where P is measured in Joules per second, m is measured in kilograms, g is the acceleration due to gravity, g = 9.8 m/s2, and v is measured in meters per second.
thanks, think i must have been dropped on my head as a baby... i was aware of the weight/mass difference but not pounds / kg. think I am having a bad day, any chance you could do an example equation with numbers that i can follow from start to finish? i don't want to waste your time for too long. is there an ebook link i could bookmark for future?
got it i think, its the units that I am unsure of but:
90kg x 9.8ms gravity x 16 kph x 10 degrees = power needed of 141,120 joule/min or 2352 watts.
my issue was 141120 looked ridiculous to me and i had to work out what i was missing. hopefully I am right thanks to chrisbaird for not flaming me!
You still have a few things wrong.
You need to use the sine of 10 degrees, not 10.
sin(10) = 0.1736... this means that going up a 10 degree slope will take about
17% of the power of going straight up with the same speed.
You need the speed expressed in meters per second, since the acceleration of gravity is also expressed in meters/second. 16 km/h is (16/3.6) m/s
you had no reason to use a unit of joule/min for your answer, since minutes were not used in your units for mass, gravity or speed.
Actually this is an achievement not much faster then what a professional cyclist can achieve over an hour long climb. (something like 450w for 80 kg including bicycle), so your answer of 2352 W is still much too high.
so 90kg x 9.8ms x 4.4ms x 0.17 (sin10deg) = 659.7 joule sec which = 659.7 watts.
its the combination of unfamiliar units and algebra not to mention the silly mistake not converting the kph that was the problem. i was pretty sure 2000+ watts was too much but couldn't see wood for the trees. its only my hobbies that ever bring me near a calculator. i haven't studied for 20 years, as you can tell!
Thanks and thanks for your patience.
I've come across this discussion while asking similar questions myself re: aircraft climb performance. Pls see attachment at my thread above to visualize the problem.
So, judging from your responses and assuming nil winds @ standard ISA conditions (t = 15°C; ρ = 1.225 kg/m3), the power required to climb an aircraft from sea-level to 2,000' will be:
Engine's rated power: 230 BHP (~172 kW)
Aircraft's weight: 2,950 lbs (1,338.1 kg)
Vy (best-rate-of-climb speed): 78 knots (40.13 m/s)
Climb rate @ Vy: 1010 fpm
Climb gradient: 1010 fpm / 78 knots = 12.95%
sin(θ): sin(12.95) = 0.224079
Code:
P = mgv sin(θ) => 1,338.1 x 9.8 x 40.13 x 0.224079 = 117,919 J/s = ~118 kW
Does it imply that an aircraft engine is working @ 118/172 = ~69% of it's rated power?
Thank you!
Rustam
Thank you!
Rustam
Without actually repeating your sums, that sounds a very reasonable answer. You would smell a rat if the result came out greater than the plane's rated power!
This looks a bit odd, though
because you have mixed your units. fpm should be converted to kts or, better still, both should be converted to m/s. Perhaps you did this but didn't show the workings.
Correct, thanks for the hint, Sir! But the result is not that different... However:
1010 fpm = 5.13 m/s
78 knots = 40.13 m/s
Climb gradient = (5.13 / 40.13) x 100 = 12.79%
sin(θ) = sin(12.79) = 0.221301
Therefore,
Code:
P = 1,338.1 x 9.8 x 40.13 x 0.221301 = 116,457 J/s = ~117 kW
Engine's working regime = 117/172 = ~68%
Thanks!
Although I'm satisfied with above results, the fundamental question I'd like to ask is:
What is the rate of change of POWER with climb?
Logically, any vehicle (and aircraft, in particular) climbing up the hill is doomed to lose power directly proportional to the height of climb. And at some point in time it will just stop climbing! In other words, the more a vehicle climbs, the more excess power it needs at his disposal. This can be clearly seen on the attachment as well - the higher the aircraft climbs, the less is the speed, climb rate (nose pitch and angle of attack) and engine performance (although the latter is not visible on the chart, it can be deduced applying the same formula in above posts to different altitudes).
So, is there any formula to calculate the rate of change of power keeping the relationships with speed, climb rate and other factors (like temp, density, etc), if any?!?
Thank you!
Rustam
I don't see why you would necessarily lose power when climbing. For air-breathing engines, indeed the higher you climb the less air (and hence power) you have, but this will also vary depending on what type of engine you have and isn't a necessary constraint. So the power requirement for climbing should remain the same, but the means of producing this power CAN diminish.
Actually, power requirements for climbing can even decrease if you take into account diminishing gravity...
Are we confusing the terms Power and Energy here? Some of the statements could use the words interchangeably and mean different things.
There are practical reasons why a normal IC engine might lose power at height but that wouldn't apply to electrical propulsion or an IC engine with its own oxygen supply.
I should have mentioned that by "vehicle" I meant an aircraft. Unlike a car, an aircraft must cope with effects of drag and gravity more than a car mostly subject to ground friction. Therefore, energy saving and particularly the notion of "excess power" is of crucial importance for any aircraft regardless its mode of flight - climb or level. Hence my question - is there a formula or approach to determine the relationship between (i) the rate of change of power with altitude; (ii) decrease in speed and climb rate; and (iii) effects of other factors such as air temp, pressure and density.
PS: Btw, did you take a look at attachment from my previous post? It will definitely help you to visualize my point here.
Well, I hope not! But I may be mistaken... At least that's what it says here: http://flysafe.raa.asn.au/groundschool/umodule1b.html#climb_forces
These pages are very good but since they're aimed at pilots (who usually use flight computers to concentrate on a flight rather than wasting time with complex calculations), a lack of thorough technical discussion is obvious and pretty welcome.
Rustam
I understand what you're saying and the concept of "excess power" (power beyond what is necessary for level flight). I believe perhaps you used the terms "power" and "excess power" interchangeably. This being a physics forum, the term "power" has a specific meaning. Basic physics for a car, plane, rocket are the same: a steady climb should require a steady power (unless some variable changes).
I saw the attachment, and indeed it appears that the plane loses power as it climbs, and I still suspect it is direclty related to decreasing air pressure. For an air breathing engine, less air means less power. Nevertheless, the power required to maintain the climb remains the same (it actually probably decreases). But since the "excess power" of the plane decreases, so does it's rate of climb. It's engine is getting weaker, as it's simply running out of breath.
I don't know the formula for this but I'm guessing the air pressure is the driving factor.
I went back to this post and I would like to point out the inconsistancy, as I believe my above post might be confusing.
As sophiecentaur said this might be true due to practical reasons (less air), but it's not nesessarily so as it's not the result of some fundamental physical law.
This is NOT true. To maintain the climb, it needs the same power, and the same excess power. What is preventing the plane from maintaining the climb, is that it simply does NOT have the same excess power. Its excess power is decreasing with altitute: the engine is getting weaker. The necessary power to maintain the climb, however, remains the same.
There are too many variables involved here to make a definite statement about the situation. If a vehicle (car) is driving up an incline and is totally self powered, the energy needed per metre of height is constant until g reduces significantly (and that is only at immense heights - do the 1/rsquared sums). At a given speed, the drag would be less as height increases.
For an aircraft which is using the air for lift then its design will be optimal for a certain air density. This could favour a very high altitude (as with the U2 spy planes) so the power needed to climb may be less at high altitude. Then the characteristics of a 'real' engine are almost bound to involve loss of power beyond a certain height. This may not actually be relevant to the original question - if the question is to be answered literally.
I think the question needs to be broken down into parts, each of which stands a chance of being answered.
Lsos is absolutely correct. If you define excess power as power over or under power required to maintain speed at fixed altitude or on level ground, then constant rate of climb will require constant excess power.
While the power requirement will change with altitude, the excess power requirement will remain the same.
I agreee to an extent (I even mentioned that power requirement may fall due to diminishing g and diminishing air resistance). However, I brushed these variables aside and simplified the situation based on the following statement by OP:
which led me to believe that OP thinks there is some intrinsic property of gravity which tends to pull down an object harder the higher we go, when in fact the invere is true. I primarily wanted to get that out of the way and not cloud the issue unnecessarily.
  • · Replies 24 ·
  • · Replies 38 ·
  • · Replies 16 ·
