Calculating Power for Roll Forming Machines: Theory and Practical Applications
The discussion focuses on calculating the power required for a 10-step roll forming machine, emphasizing the relationship between processing speed, frictional losses, and energy investment to reach the yield point of materials. Key factors include the material type (steel with a yield strength of 250 MPa and tensile strength of 410 MPa), thickness (2 mm), and the specific C purline section profile. The conversation references Bhattacharya's formulas and suggests that textbooks like Groover's "Introduction to Manufacturing Processes" and Kalpakjian's "Manufacturing Engineering and Technology" contain relevant equations for roll forming calculations.
  • Understanding of roll forming principles and processes
  • Knowledge of material properties, specifically yield and tensile strength
  • Familiarity with mechanical engineering concepts related to force and energy
  • Access to manufacturing engineering textbooks for theoretical background
  • Study the equations for roll forming as outlined in Groover's "Introduction to Manufacturing Processes"
  • Research the "Bhattacharya formula" for calculating energy in roll forming
  • Learn about energy recovery techniques in roll forming processes
  • Explore software tools for simulating roll forming operations and power calculations
Manufacturing engineers, mechanical designers, and production managers involved in the design and optimization of roll forming machines.
Tpatel56
How to calculate power of roll forming machine? Is there any theory for calculation?
Actually i am designing 10 step roll forming machine, But confuse about power calculation...
Power required will be proportional to the speed of processing. There will be frictional losses.
When you bend sheet metal you must first invest energy to take it to the yield point.
Then during the plastic deformation phase, the force multiplied by distance of movement gives energy cost of the bend.
After each roller stage you might be able to retain or recover some of the elastic energy that was invested earlier while reaching the yield point.
Is their is mathematical formula for whole process...?
Not that I know.
If you know the force or torque required to bend a set length of the material through a set angle, you can then work out the approximate forming energy per unit length. To do that you must find the total angle in degrees of all the bends in the final section.
I know some formula of bhattacharya...but not knowing exactly how to calculate final power by considering all roller.
1. What is the sheet material, steel, aluminium ?
2. What is thickness of the material ?
3. Please give a section profile of the rolled product ?
4. What "formula of bhattacharya" do you have ?
1. steel with Yield strength - 250 Mpa & Tensile Strength - 410 Mpa
2. Thickness of material - 2 mm
3. C purline section. refer below image for same. where H = 70 mm, B = 40 mm, C = 15 mm
https://www.google.co.in/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0ahUKEwi1zZ3xy__RAhVC0oMKHWXTAPoQjRwIBw&url=http%3A%2F%2Fliancheng.e.tradeee.com%2Fproduct_view%2F52115198%2FC_Purlin__Z_Purlin.html&bvm=bv.146094739,d.amc&psig=AFQjCNFB_cZ6wfFNDbFktkEpgyEwPbvRXg&ust=1486612085559330
4. I am referring this book "D. Bhattacharyya, P.D. Smith, The Development of Longitudinal Strain in Cold Roll Forming and its influence of Product Straightness, Advanced Tech. of Plastictiy, Vol. 1, 1984"
The equations for roll forming are covered in textbooks like Groover's Introduction to Manufacturing Processes or Kalpakjian's Manufacturing Engineering and Technology.
Do you have web link for this book then please share with me...
