Power output of an anchored propeller
The discussion revolves around calculating the power output of a propeller anchored to a load cell, specifically focusing on the relationship between power input, lift produced, and efficiency. Participants explore the complexities of measuring thrust and translating that into power output, considering various theoretical and practical aspects of propeller dynamics.
  • One participant describes their setup with a propeller anchored to a load cell to measure lift and seeks to understand how to calculate power output and efficiency.
  • Another participant suggests that the propeller's orientation is akin to a helicopter, implying that lift calculations may follow similar principles.
  • Several participants note the challenge of linking force measurements to velocity calculations, with one expressing frustration over the lack of clear examples online.
  • There is a mention of needing to build an efficiency curve, with some participants clarifying that thrust is the relevant measure rather than speed.
  • One participant emphasizes that power output is not straightforward to calculate when the system is stationary, suggesting that power in the fluid jet could be a more relevant measure.
  • Another participant points out that thrust calculations are complex and must consider the weight of the system.
Participants generally agree on the importance of thrust in relation to power output, but there is no consensus on the method to calculate power output from thrust measurements. The discussion remains unresolved regarding the best approach to link these variables.
Participants express uncertainty about the relationship between thrust and power output, particularly in stationary conditions. There are unresolved mathematical steps in linking force measurements to velocity and power calculations.
Leon (AW)
I have a motore with a propeller anchored to a load cell to measure the lift produced at varying power inputs. This is for a student activity I am running and I wanted to show that though more power in gives more lift there is a point after which efficiencey starts to go down again so I tried to also calculate the power output of the propellers to get the efficiency of the blades.
***Edit***:Thought of a better way of explaining this. if it was a fixed wing I would move it D distance in T time generating F force and my power would be F*D/T. but for a rotating blade the distance D it moves in T time depends how close to the end you are and I can't figure out how to calculate ecounting for that.
Any help would be great thanks.
***old thoughts***
I thought at first the propelor would effectively have potential energy as it applies a constant force like gravity does but the energey in goes up by time where the potential goes up by time squared.
I tried to calculate the speed it would have if not anchored by picking an arbitrary time and deviding by the mass however as you can see from the attachment that's wrong as it would accelerate for ever so the power out increases with time while the power in stays the same.
Any idea how I can work this?
Should my speed be the rotational speed of the propeller maybe? (or would that just give me the power output of the motor).
maybe I need to calculate the volumetric air flow from pressure (getting pressure from force and propeller area) and take speed from that.
Hi Leon (AW). So you have turned your propeller to point vertically upwards, like a simple helicopter or powered gyrocopter, and wish to calculate the lift it produces? I reckon a google search should turn up a lot of useful information, you surely wouldn't be the first to ponder this!
Good luck, and Happy Easter!
I have googled it for hours but everything I have found either requires it moves or only measures forces. I likely have all the equations I need to figure this out I'm just not making the link somewhere between two of them. That's why I came here to see if anyone can point out the bit I am missing that will be obvious once I know it.
I'm usually pretty good with figuring this stuff out but I'm just drawing a blank this time and can't find an example online. I think it is because I am so used to figuring out power by measuring velocity and calculating out the force to put into a power equation whereas this time I am measuring the force and trying to calculate the velocity. Every time I try I get the power increasing with time.
So you are trying to build a efficiency curve, right?
satchurated said:
So you are trying to build a curve off efficiency
Yes, I know the power in but I can't figure out how to calculate power out.
You mean thrust..
satchurated said:
You mean thrust..
It is chained to a load cell I can read thrusting force of the screen. what I want is, knowing the mass of the object, how much power will that thrust be worth if i were to cut the chain.
if I cut the chain I could measure it's speed and calculate the thrust from it's mass. with the chain I can measure it's thrust so how do I calculate it's potential speed from it's mass.
If you're studying the dynamics of a multirotors, speed is not so important as you think
More power in will continually give more thrust (up to a limit) however the peak efficiency, where the law of diminishing returns starts to kick in, is not obvious on a power to thrust graph. It is obvious on a power into power out graph though.
One thing is power to thrust, which is different to speed as you talk. The force is not calculated as above, but in a way more complex because thrust needs to take into account the weight
If it's stationary, power out is zero :)
Alternatively, you could calculate the power in the fluid jet, which would be 0.5 times the mass flow rate of the fluid times the square of the jet velocity (and you'd have to somehow measure or estimate the jet velocity and mass flow rate). There is no simple conversion purely based on thrust though.
  • · Replies 21 ·
  • · Replies 31 ·
