Power Rule Proof: Get Help with Line 3 to Line 4
The discussion centers on understanding the transition from line 3 to line 4 in a mathematical proof involving derivatives. Participants clarify the significance of the ellipsis in the expression, indicating that it represents a continuation of terms, leading to the conclusion that the derivative is ##f'(a) = na^{n-1}##. There is a focus on correctly interpreting the pattern of terms and the importance of manipulating expressions to grasp the underlying concepts. Additionally, advice is given on problem-solving strategies, emphasizing patience and the need to explore different approaches before seeking help. The conversation highlights the learning process in mathematics and the value of persistence.
member 731016
Pls see below
Pls see below
For this proof,
I am unsure how they got from line 3 to line 4.
If I simplify and collect like terms for line 3 I get ##f'(a) = 4a^{n-1}##
Would some please be able to help?
Many thanks!
What does ##a^n## mean? It is ##\underbrace{a\cdot a\cdot \ldots\cdot a}_{n\text{ times}}.## Hence for ##n=i+j## we get $$a^n=\underbrace{a\cdot a\cdot \ldots\cdot a}_{n\text{ times}}=\underbrace{a\cdot a\cdot \ldots\cdot a}_{i \text{ times}} \cdot \underbrace{a\cdot a\cdot \ldots\cdot a}_{j\text{ times}}=a^i \cdot a^j =a^{i+j}$$
Likes member 731016
Thank you for your reply @fresh_42!
Did I not add the exponents correctly? For example, ##a^{n-2}a^1 = a^{n-1}##
Many thanks!
That's not at all what you did wrong. You missed the significance of the ... in the first of the expressions you circled.
The expression ##a^{n-1} + a^{n-2}a + \dots + aa^{n-2} + a^{n-1}## does NOT have just four terms in it. The ... in the middle is called an ellipsis, and means "continuing the same pattern." In fact, this pattern indicates that there are n terms in all, thus leading to the conclusion that ##f'(a) = na^{n - 1}##.
Likes member 731016
Thank you for your reply @Mark44 !
I see what you mean about me missing the dots.
However how dose,
##a^{n-1} + a^{n-2}a + \dots + aa^{n-2} + a^{n-1} = na^{n-1}##?
Many thanks!
However how dose,
Many thanks!
Try writing it out explicitly for n=5.
Likes member 731016
However how dose,
Many thanks!
\begin{multline*}<br /> \overbrace{a^{n-1} + aa^{n-2} + \dots + a^{k}a^{n-1-k} + \dots + a^{n-2}a + a^{n-1}}^{\mbox{$n$ terms}} \\<br /> = \overbrace{a^{n-1} + a^{n-1} + \dots + a^{n-1} + \dots + a^{n-1} + a^{n-1}}^{\mbox{$n$ terms}} = na^{n-1}\end{multline*}
Likes member 731016
@Callumnc1 I worry about how much you are learning given the large number of problems you are posting. I would suggest going back and looking at the problems you have posted and seeing if you can solve them without help. If you have issues with many of them, then all PF is doing is helping you solve problems, not learn the material.
Likes SammyS, member 731016 and Mark44
Thank you for your reply @pasmith ! Sorry, how did you get you last result:
pasmith said:
\begin{multline*}<br /> \\<br /> = \overbrace{a^{n-1} + a^{n-1} + \dots + a^{n-1} + \dots + a^{n-1} + a^{n-1}}^{\mbox{$n$ terms}} = na^{n-1}\end{multline*}
Many thanks!
Thank you for your reply @Frabjous ! Yes I agree with you suggestion! I will definitely try to solve the old threads!
Many thanks!
For n = 5, then
##a^{n-1} + a^{n-2}a + \dots + aa^{n-2} + a^{n-1} = a^4 + a^4 + a^4 + a^4 = 4a^4## (I am unsure what the dots mean)
Many thanks!
Callumnc1 said:
For n = 5, then ##a^{n-1} + a^{n-2}a + \dots + aa^{n-2} + a^{n-1} = a^4 + a^4 + a^4 + a^4 = 4a^4## (I am unsure what the dots mean)
No, that's wrong. You should not have the dots (ellipsis) here. For n = 5, and writing all of the terms in the first expression you circled, we have:
##a^4 + a^3a + a^2a^2 + aa^3 + a^0a^4 = ##
##a^4 + a^4 + a^4 + a^4 + a^4 = 5a^4##
This means that if ##f(x) = x^5##, then ##f'(x) = 5x^4## and ##f'(a) = 5a^4##.
As for the meaning of the dots, please reread post #4 in which I explained what they mean.
Likes Frabjous and member 731016
Thank you for your help @Mark44!
Sorry, so for n = 5, continuing the pattern will give ##a^2a^{n-3} = a^4##, correct? Now I need to generalize that for n which is hard.
EDIT: That's what @pasmith has done, I understand now :)
Many thanks!
Thank you for help @pasmith ! I understand now :)
Many thanks!
The thing to notice is that the exponents go from (n-1) to 0 and 0 to (n-1) which is n terms.
In general, you need to spend more time staring at and manipulating things. Be patient. Problems take time to solve, otherwise we would call them easies.
Likes member 731016 and Mark44
Thank you for you reply @Frabjous!
I agree with your advice! How long should try solving the problem for before looking at the solution?
Many thanks!
Until you have run out of ideas. Ideally, you would go away for a while and try again before looking. Part of problem solving is to figure out different ways of going after a problem. Hopefully one of them will work. When you get a hint from PF, play with it for a while before asking for additional help.
For this problem, you should have tried to solve it for a specific value of n starting at the xn-an stage. You would have at least learned what an ellipsis is.
Likes member 731016
Thank your for your advice @Frabjous! I will try to do that more!
