Power spectral density question
  • Thread starter Thread starter okami11408
    Density Power
The discussion revolves around the concept of power spectral density (PSD) in the context of signals in the frequency domain. Participants explore the rationale behind defining power in terms of PSD rather than simply using the Fourier transform of a power signal.
  • One participant questions the necessity of defining power spectral density, suggesting that a Fourier transform of the power signal should suffice.
  • Another participant explains that PSD represents the average power at a specific frequency over a long time, emphasizing the importance of time averaging for real signals.
  • A different viewpoint highlights that knowing the power of a signal alone is insufficient without understanding its distribution across frequencies, which PSD provides.
  • One participant illustrates the concept using a square pulse and its Fourier transform, noting that most power is concentrated in the first lobe of the sinc function, which is critical for channel design.
  • Several participants express confusion regarding the utility of the Fourier transform of power, questioning its relevance compared to PSD.
  • Another participant mentions that estimating PSD involves calculating the Fourier transform but acknowledges the complexity of accurately estimating PSD for real signals.
Participants generally agree on the usefulness of power spectral density but express differing views on the relevance and utility of the Fourier transform of power. The discussion remains unresolved regarding the comparative significance of these two approaches.
Participants indicate that estimating PSD is not straightforward and involves various algorithms, suggesting limitations in the simplicity of calculating it directly from the Fourier transform.
okami11408
Normally, when we dealing with power signal in frequency domain we usually use power spectral density.
My question is why is that? Why we define the power P(f) this way.
http://img21.imageshack.us/img21/6786/powerec.jpg
This makes no sense to me, Why don't we just Fourier transform p(t) therefore we also get P(f)
http://img198.imageshack.us/img198/8603/power2a.jpg
I just don't get the concept of power spectral density.
Please help!
You want a practical relevance of P(f)?
P(f) is just the average power over a long (infinite) time at frequency f. A real signal will vary in time so, to get a useful idea of the amount of power around a particular frequency, you need to measure it and average it over a long time - or you could miss something.
You could also do an FT on p(t) but that would also involve knowing p(t) over an infinite time interval so how would it necessarily be any easier?
On a theoretical level, you are just questioning the 'point' of an identity. Well, you could do that for many (all) identities. You could just as easily ask what's the point of the multiple angle formulae.
An identity is just a useful relationship that sometimes makes calculations easier.
I don't know what you are studying, but in communications knowing the power of signal means nothing to you.
Let's see what I mean by this.Say you have a 1 W signal. This 1 W of power can be spread over 10 Hz or 10 MHz, you don't know that. Knowing the power spectral density gives you the advantage to know in which part of you spectrum the power is concentrated mostly.
Then when you integrate the PSD in some frequency range, you get total power in that frequency range.
For example, take a FT of square pulse.
Its a sinc function right? Most of its power is concentrated in that first arcade(first lobe). If you would integrate the PSD in the frequency range of the first lobe, you would get that it takes up around 90% of total power of the square pulse.
Information like this is crucial, when you are designing channels.
Thanks you for the answers!
Now I see that knowing power spectral density is useful,
but why does the Fourier transform of power mean nothing?
Because the Fourier Transform of p(t) shows power at each frequency, suppose I get sinc function from Fourier Transform p(t), it shows that most of a component that create this power signal signal has frequency of -10hz - 10hz (say first lobe of a since function is -10hz - 10hz)
This is not useful?
This is not useful?
I don't understand what this means, actually.
I am not sure I understand the question. Most methods for estimating the PSD DOES involve calculating the Fourier transform.
However, actually estimating the PSD for a real signal is by no means trivial, and there are many different algorithms for doing so (Welch method is perhaps the most widely used one). It is (unfortunately) not as easy as just calculating the FFT.
  • · Replies 0 ·
