Power transformed when resistance is zero and infinite
8 replies · 4K views
Janiceleong26
1. Homework Statement
P=IV,
=I2R
=V2/R
For zero resistance, I used P=V2/R formula, and sub. R=0 , power would be infinite. But if I sub. Into P=I2R, power will be zero. The correct answer should be zero. But why do we need to use the second relevant equation I typed above?
For infinite resistance, I used P=V2/R and so will result in power tending to zero.
I am confused on when to we use which equations to calculate power
Both R and V go to zero, so you have "0/0" which is undefined. You cannot use this formula.
Oh I see.. Thanks
But if resistance is infinite, then shouldn't voltage be infinite too?
mfb said:
No. Why do you expect this?
Because V=IR, V α R, though I feel that it doesn't make sense to have an infinite voltage..
Remember we are talking about the voltage drop across Q.
V α R is only true at fixed current.
What is the current you expect for infinite resistance?
And, as cross-check, can the voltage at the resistor exceed the source voltage?
Zero current :biggrin:
Oh yeah.. Never thought of that too, thanks!
