Is the Rationale for Preparing 1mg/ml BSA in 1ml Distilled Water Correct?
The discussion centers on the preparation of a 1mg/ml BSA solution for total protein estimation using the Lowry method. It is established that adding 1ml of distilled water to 1mg of BSA in a 2ml Eppendorf tube is an acceptable practice due to the difficulty in accurately measuring small quantities like 1mg. The accuracy of this method is deemed sufficient for most biochemical assays, although for higher precision, alternative methods such as UV/vis spectrophotometry should be employed to verify concentrations. The conversation highlights common misconceptions regarding precision in laboratory procedures, particularly among students.
  • Understanding of Bovine Serum Albumin (BSA) and its applications in biochemical assays.
  • Familiarity with the Lowry method for protein estimation.
  • Basic knowledge of Eppendorf tube usage and measurement techniques.
  • Awareness of UV/vis spectrophotometry for concentration verification.
  • Research the Lowry method for protein estimation and its limitations.
  • Learn about UV/vis spectrophotometry and its application in measuring protein concentrations.
  • Explore best practices for preparing solutions with low solute concentrations.
  • Investigate the impact of measurement errors in biochemical assays and how to mitigate them.
Biochemists, laboratory technicians, students in life sciences, and anyone involved in protein analysis and preparation techniques.
TytoAlba95
I had to prepare 1mg/ml BSA for Total protein estimation by Lowry method. I was suggested to add 1ml distilled water to 1mg of BSA in a 2 ml ependoff tube, instead of adding distilled water upto the 1ml mark. The explanation that was given to me was, that, 1mg is a very small amount and it doesn't affect the total volume, much if we add that to 1ml of dH2O. Also as BSA crystals doesn't dissolve easily, and forms froth in the process of dissolving, it becomes more difficult to add water till the1ml mark, as the miniscus isn't formed.
So my question, is the rationale correct? (It sounds okay to me)
Should I be doing this for all solutions where the amount of solute is very less (<1g?)?
Biology news on Phys.org
It depends on how accurate you need to be. For most applications (e.g. preparing protein standards for common biochemical assays), the method you describe is fine. It is very difficult to measure out 1mg, so there will be a lot of error associated with that step, and using the marks on the Eppendorf tubes to measure out 1mL is also not very accurate, so adding 1mL of water to 1mg of BSA is probably not going to be much more accurate and reproducible than dissolving 1 mg of BSA to 1mL of total solution.
If you need more accuracy, I'd probably use an orthogonal method (e.g. UV/vis spectrophotometry) to measure the concentration of the solution you create and use that measured concentration as the real concentration rather than assuming it is 1 mg/mL.
Thank you.
Common error or deformation amongst students and beginners (I guess induced by brainwashing and didactic terrorism) to do with high precision a procedure step when other steps before or after have intrinsically considerably less precision, thus wasted time and effort.
When you measure protein concentration by the Lowry method, you are dependent on the assumption that the extinction coefficient of the coloured product formed from your protein is the same as that formed your albumin standard (reflecting rough similarity(?) of amino acid compositions especially aromatic aa's between one and the other). Good luck with that. If you're measuring, I don't know, say total albumin levels in circulating blood, that may be good enough. And if you're only interested in the variation of these levels according to something else, well even a systematic error would not affect your conclusions very much. Yes it will practically always be a lot better than just order of magnitude, but I have known a case where estimating protein concentration of a purified protein of which only small quantities were available give the conclusion that there were four binding sites for certain ligands per protein molecule.Later better investigations some years later showed that instead there were six sites per molecule.
