Preparing a Solution using ppm and ppb -
6 replies · 5K views · last reply
Zghakt
I would like to prepare 50.0 g of 50 ppb Pb standard solution in 1% HNO3 gravimetrically, in a 50.0mL plastic tube from a stock solution of 50 ppm Pb.
From what I understand, this is a dilution...so C1V1 = C2V2
I like working in mg/L more than ppb and ppm so I converted
50 ppb = 0.05 mg/L
50 ppm = 50 mg/L
C1V1 = C2V2
50 mg/L V1 = (0.05 mg/L)(0.05L)
V1 = 0.00005L or 0.05 mL
so then 0.05 mL of 50 ppm Pb and 49.95 mL of HNO3.
Would this be the proper way to prepare this solution?
Zghakt said:
gravimetrically
"Gravimetrically?" Or, by volume? At this concentration, a significant fraction of solute is going to be adsorbed on the surfaces of vessels/flasks/containers; are you concerned, or have you made allowances for such an effect?
This is my first time preparing a solution given the above directions. My instructions stated to prepare the solution gravimetrically. However, I could only figure out how to prepare the solution by volume, ie: 0.05 mL of 50 ppm Pb and 49.95 mL of HNO3. Would you suggest there is a more effective way to make the solution?
50 ppb = 0.05 mg/L
50 ppm = 50 mg/L
C1V1 = C2V2
I doubt you do want to prepare 50 g at 50 ppb - that would be a billion liters wouldn't it?
You had better state or find out what you mean by a billion as there are two different meanings round.
If it is thousand million then you have tondilut your 50 ppm a thousand times. Burt I'm not sure you knows what this means.
I suppose 50 g refers to the mass of the solution, not of the solute.
I misread and thought it was saying 50g of Pb! He also says 50 ml. For his practical purposes I guess it is good enough to. Insider these two the same thing.
Okay, does this mean the original calculations I posted (see first post) would be correct to prepare the solution then? I can clarify with the person who wrote the directions by what the 50g refers too (either solute or solution)
