Pressure measuring device sensitivity
The discussion focuses on deriving the liquid deflection (L) in an inclined tube reservoir manometer and determining its sensitivity (S) in relation to the applied pressure difference (Δp). The sensitivity is expressed as S = L / h_e = 1 / (SG_L (sin θ + (d/D)²)). To maximize sensitivity, participants suggest differentiating the diameter (D) with respect to the angle (θ) and the diameters (d and D) to find critical points. The conversation emphasizes the importance of considering all parameters affecting sensitivity for optimal results.
  • Understanding of fluid mechanics principles, particularly manometer operation.
  • Familiarity with specific gravity (SG) calculations.
  • Knowledge of calculus, specifically differentiation techniques.
  • Basic concepts of pressure measurement and its applications.
  • Study the derivation of liquid deflection in inclined manometers.
  • Learn about optimizing sensitivity in pressure measurement devices.
  • Explore the effects of specific gravity on manometer readings.
  • Investigate advanced calculus techniques for maximizing functions.
Students and professionals in engineering, particularly those specializing in fluid dynamics, pressure measurement, and instrumentation design.
stunner5000pt
An inclined tube reservoir manometer is constructed as shown in the figure. Analyze the manometer to obtain a general expression for the liquid deflection L in the inclined tube in terms of the applied pressure difference \Delta p. Also obtain a general expression for the manometer sensitivity, and determine the parameter values that gives maximum sensitivity
The diameter of the large area is D
diameter of the tube is d
H is the difference in heights between the h and H
SGL is the specific gravity of the liquid in question
I already solved for L and that expression is used to get the sensitivity
i have no problem getting the sensitivity which is given as
S=\frac{L}{h_{e}}=\frac{1}{SG_{L}\left(\sin\theta+\left(\frac{d}{D}\right)^2\right)}
but they ask to maximize the sensitivity
should i simply differentiate D with respect to theta, D and d and then determine the critical points?
is this enough to maximize sensitivity or i there more i should consider?
thanks for your help
can anyone offer any help or input?
thanks a lot
