Probability density function of uniform distribution
The discussion focuses on finding the probability density function (PDF) of the random variable Y, defined as Y = √X + 1, where X is uniformly distributed on the interval [0, 1]. Participants clarify the transformation from Y to X and the correct formulation of the cumulative distribution function (CDF) F_Y(y) based on the relationship between Y and X. Key points include ensuring that the range of Y is correctly identified as [1, 2] and that the CDF should reflect this range. The final PDF f_Y(y) is derived by differentiating the CDF and must include appropriate constraints. Overall, the conversation emphasizes correcting errors in the transformation process to arrive at the correct PDF for Y.
diracdelta
Random variable X is uniformly distributed on interval [0,1]:
f(x)=\begin{cases} 1 & \text{ if } 0\leq x\leq 1\\ 0 & \text{ else} \end{cases}
a) Find probability density function ρ(y) of random variable Y=\sqrt{X} +1
I tried like this. Is it good, if no why not?
F_{Y}(y)=P(Y\leq y)=P(x^{2}+1\leq y)=P(x\leq y^{2}+1)=F_{x}(y^{2}+1) \\ f_{X}(x)=F_{X}'(y^{2}+1)=f_{X}(y^{2}+1)* \left | \frac{d}{dy} (y^{2}+1)\right |=f_{X}(y^{2}+1)*2y \\ f_{Y}(y)=\begin{cases} 2y & \text{ if } 1\leq x\leq 2\\ 0 & \text{ else} \end{cases}
How did \sqrt{X}+ 1 become X^2+ 1? If you intended the inverse function then it should be X= (Y- 1)^2
Likes diracdelta
Hmm, i see.
Ok then, i get this
F_{Y}(y)=P(Y\leq y)=P(x^{1/2}+1\leq y)=P(x\leq (y+1)^{2}) =F_{x}(y+1)^{2} \\ f_{X}(x)=F_{X}'(y+1)^{2}=f_{X}(y+1)^{2}* \left | \frac{d}{dy} (y+1)^{2})\right |=f_{X}(y+1)^{2})*2y \\ f_{Y}(y)=\begin{cases} 2y & \text{ if } 1\leq x\leq 2\\ 0 & \text{ else} \end{cases}[/QUOTE]
But what about y's probability density function ?
Is it ok?
diracdelta said:
##F_{Y}(y)=P(Y\leq y)=P(x^{\frac 12}+1\leq y)##
That should really be
##F_{Y}(y)=P(Y\leq y)=P(X^{\frac 12}+1\leq y)##
diracdelta said:
##=P(x\leq (y+1)^{2}) ##
Check that step.
diracdelta said:
##f_{X}(x)=F_{X}'(y+1)^{2}=f_{X}(y+1)^{2}* \left | \frac{d}{dy} (y+1)^{2})\right |##
##F_{X}'((y+1)^{2})## just means the derivative wrt x of FX(x) evaluated at x = (y+1)2
##f_{X}(x)=F_{X}'((y+1)^{2})=f_{X}((y+1)^{2})##
diracdelta said:
Hmm, i see.
Ok then, i get this
Is it ok?[/QUOTE]
How do you get from ##x^{1/2}+1 \leq y## to ##x \leq (y+1)^2##? (I don't.)
Anyway, since ##X## ranges from 0 to 1, so does ##\sqrt{X}## and that means that ##Y = 1 + \sqrt{X}## ranges from 1 to 2. So, you ought to have ##F_Y(1) = 0## and ##F_Y(2) = 1##. Do you have that?
Up to here it's OK, except for the two errors pointed out by haruspex. Fix those and you will have a correct formula for ##F_Y(y)## in terms of ##F_X## applied to some function of ##y##.
Next you can use the fact that ##F_X(x)=\int_0^x f_X(u)du=\int_0^x du=x## to write a formula for ##F_{Y}(y)## in terms of ##y##.
Forget about everything you wrote below your first line, as that heads off on a goose chase involving ##f_X## and there is no need to refer to ##f_X## any further.
Differentiating your formula for ##F_Y(y)## will give you a formula for ##f_Y(y)##.
To complete the answer you need to put range constraints into your expression for ##f_Y##, along the lines suggested by Ray.
