Play the Probability Game: Test Your Luck!
  • Thread starter Thread starter Shackleford
    Game Probability
The discussion revolves around a probability problem involving a game where participants are trying to determine the probability of winning based on the number of tries. The context includes concepts related to Markov chains and probability distributions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the probabilities associated with winning in different numbers of tries, questioning the relationships between outcomes and the assumptions of the game setup. Some suggest breaking down the problem into special cases to identify patterns.
The discussion is ongoing, with participants sharing insights and attempting to clarify their understanding of the problem. Some have provided specific examples and calculations, while others are seeking clearer answers and more concrete numerical examples.
There are references to the complexity of the problem and the potential need for familiarity with Markov chains. Some participants express frustration with vague responses and emphasize the importance of providing clear numerical answers.
Well, firstly
P(win| R_0 = 1) = P(win| R_0 = 2) = P(win| R_0 = 3) = P(win| R_0 = 4).
So you just need to find anyone of them and that's your probability.
Now do it for special cases -
1. What is the probability that he wins in 1 try?
2. 2 tries?
3. 3 tries?
4. 4 ... ?
Do you see a pattern?
The answer is then the infinite sum
P(win) = [itex]\sum_{n=1}^{\infty}[/itex]P(win in n tries)
Well, I suspected some sort of pattern last night. If you break up one of those tries into "equals 1" and "not equals 1," the "not equals 1" will translate into R2=R1, R2=R0, and again R2 not = R1.
Well, so did you work it out? Kindly post what you have been able to do.
I just got home.
Oh, I'm supposed to work out when you win in a certain number of tries. Let me do that in a few minutes.
Shackleford said:
I just got home.
This problem is actually fairly tricky unless you are used to Markov chain sorts of problems. It branches depending on whether you win or continue at stages. Took me a few false tries to get it right. But praharmitra is correct. Doing some special cases of n will really help to see the general pattern.
I have heard of Markov chains, but I have no idea what they are nor have I encountered them in coursework.
This is probably not correct.
http://i111.photobucket.com/albums/n149/camarolt4z28/IMG_20110409_224337.jpg?t=1302407152
Ok, so what is that blurry thing you posted supposed to tell me? What is the probability of winning at say n=1, n=2, n=3 and n=4? Solving the whole question may be a little subtle, but those special cases are easy. Do them. Do something.
It's not only not correct. It has no content whatsoever. Give us some numbers. A Markov chain is a sequence of events where you have a potentially infinitely recurring state. This is one. There may be a more elementary way to solve this but I haven't thought of it. Maybe it you just write out enough special cases of n you can see the pattern.
Well, I looked at a previous problem in the homework. This is the probability of winning in exactly n tries in this game:
http://i111.photobucket.com/albums/n149/camarolt4z28/IMG_20110409_231023.jpg?t=1302408812
Stop posting these blurry photobuckets and give me some straight answers. What is the probability of winning at n=1? That shouldn't even require much thought, much less calculation. Now n=2. You might have to think about that for a few seconds. Not much more. If you get that then do n=3. If I see another vague, blurry photobucket shot I'm out of here.
dick said:
stop posting these blurry photobuckets and give me some straight answers. What is the probability of winning at n=1? That shouldn't even require much thought, much less calculation. Now n=2. You might have to think about that for a few seconds. Not much more. If you get that then do n=3. If i see another vague, blurry photobucket shot I'm out of here.
Of course, you can look at each roll separately, and it's always 1/4. Right?
Wow, you evaded any meaningful answer again. Yes, your probability of getting any given number is 1/4. Now tell me something about how that would translate into a probability of winning the game at any given n. Any n, you pick.
Let me give you an example for n = 4.
Given that in the zeroth try we got R0. In the first try, we can have only 3 allowed throws with probability 3/4. In the second try, you're not allowed to get either R0 or R1, so you have two allowed throws with probability 2/4. Again third try, you are not allowed to get R0 and R2, so again probability is 2/4. Finally in the 4th try, the only allowed throw is R0, with probability 1/4. So probability for winning in 4 throws is
(3/4)(2/4)(2/4)(1/4).
Now, use the same logic and find it for more numbers (n=1 is a slightly special case, so make sure you do that too)
Shouldn't it always be 2/4 for every k not equal to 1 or n?
3*(1/4)n*2n-2
I'm off just a bit.
  • · Replies 19 ·
