What is the Probability of Engine Failure for a Plane with Four Engines?
The discussion focuses on calculating the probability of engine failure for a four-engine plane using both Poisson and binomial distributions. Initially, a Poisson approach was used, leading to a comparison of failure probabilities for two-engine and four-engine planes, resulting in the equation 1 < p/3 + p^2/12. However, it was suggested that a binomial distribution is more appropriate, where n represents the number of engines and k the number of failures. After re-evaluating with the binomial formula, the correct probability range was confirmed as 1/3 < p < 1. The conversation highlights the importance of selecting the right statistical model for probability calculations.
Addez123
Probability for an engine to fail is p.
A plane can fly using only half of their engines, for what p is it safer to use a two engine plane instead of a four engine one?
Binominal, Poisson, multinomial, Normal -distribution formulas.
Given we only have one number I assume we are to use Poisson distribution.
Probability for a plane with two engines to fail require both engines to fail:
$$P_2 = P_o(2) =p^2/{2!} * e^{-p}$$
Probability of a four engine plane to fail requires 3 or 4 engines to fail:
$$P_4 = P_o(3) + P_o(4) = e^{-p}(p^3/{3!} + p^4/{4!} )$$
This leads the the equation $$P_2 < P_4$$
$$p^2/2! * e^{-p} < e^{-p}(p^3/{3!} + p^4/{4!} )$$
$$p^2 < p^3/3 + p^4/12$$
$$1 < p/3 +p^2/12$$
$$12 < 4p + p^2$$
Which we use PQ formula to calculate the points from:
$$p^2 + 4p - 12 = 0$$
The two points are p = -2, p = 2.
The answer is 1/3 < p < 1.
I probabily did everything wrong but some hints as to where I first did wrong would be helpful.
Likes Delta2
I think your mistake is that you use Poisson distribution, while I think the problem is suitable for binomial distribution..
I did it with binomial distribution and I get the suggested answer, that is ##\frac{1}{3}<p<1##.
Hint: In using binomial distribution n is the number of engines of the plane. k is the number of the engines that fail, $$Pr(n,k,p)=\begin{pmatrix}n \\k \end{pmatrix}p^k(1-p)^{n-k}$$
Likes Addez123
Re-did it, now it works out!
Thanks!
Likes Delta2
  • · Replies 16 ·
