Probability of Two Cards Being Aces: Intro Stats Help
  • Thread starter Thread starter dherm56
    Statistics
The problem involves calculating the probability of drawing at least one ace when two cards are dealt from a standard deck of 52 cards. The context is introductory statistics.
  • Participants discuss various attempts to calculate the probability, including different interpretations of the card counts and the order of drawing. Questions arise regarding the correct use of probabilities for drawing aces versus non-aces.
The discussion includes multiple interpretations of the problem and various approaches to calculating the probability. Some participants suggest adjustments to initial attempts, while others explore the reasoning behind the calculations. There is a recognition of the need to consider different scenarios for drawing aces.
Participants note a lack of coverage on probability in their previous studies, which may contribute to confusion regarding the problem setup and calculations.
dherm56
Two cards are dealt from a deck of 52 cards. Find the probability that at least one of them is an ace.
This is for an intro. stat class and the material is very simple but for some reason I cannot find this answer. The only attempt that makes sense to compute is (48/52)*(4/51) but this is incorrect.
Not sure why you used 48 there; change it to a 4 and it should be the correct answer.
(4/52)*(4/51) is also incorrect. I used 48 the first time b/c that is all the cards besides an ace and only one needs to be drawn
What is the answer?
I'm thinking you have to add the probabilities of drawing one ace and drawing two aces. Teacher didn't cover too much in probability when I studied it...
Still no luck
Do you have the answer?
To get "at least one ace in two cards" you must either get an ace on the first card (in which case it doesn't matter what the second card is) or get a "non-ace" on the first card and an ace on the second card.
The probability that the first card is an ace is 4/52. The probability that the first card is NOT an ace is 48/52 and in that case, you still have 4 aces in the remaining 51 cards so, in this situation, the probability that the second card is an ace is 4/51. That is, the probability of "non-ace, ace" in that order is (48/52)(4/51).
The probability of "one or the other", that is the probability that at least one card of two is an ace, is the sum of those: 4/52+ (48/52)(4/51).
That's correct, thank you very much!
17K
  • · Replies 16 ·
