Problem caused by length contraction and relativity and personal expla
The discussion revolves around the implications of length contraction and relativity, particularly in relation to photons and their behavior at the speed of light. Participants explore concepts from special and general relativity, including time dilation, spacetime curvature, and the nature of mass and energy.
  • Some participants suggest that length contraction affects both observers on the ground and those in a vehicle, leading to the conclusion that distances appear shorter for the moving observer.
  • There is a claim that if a vehicle were replaced with light, the distance to a galaxy would be zero based on Lorentz's Transformation, raising questions about measuring the speed of light.
  • Some argue that photons do not have mass, and thus when they travel at the speed of light, they do not experience time dilation or spacetime warping.
  • Others clarify that time dilation is not due to spacetime warping but is a result of the Lorentzian character of flat spacetime.
  • One participant notes that while photons do not have mass, they possess energy and momentum, which can contribute to spacetime curvature.
  • There is a discussion about gravitational time dilation, highlighting that it differs from the time dilation associated with relative speed in special relativity.
  • Another participant emphasizes that general relativity serves as a predictive framework rather than a theory that explains phenomena in a straightforward manner.
Participants express both agreement and disagreement on various points, particularly regarding the nature of time dilation and the implications of mass and energy in the context of general relativity. Multiple competing views remain, and the discussion does not reach a consensus.
Some claims depend on specific interpretations of relativity, and there are unresolved mathematical steps regarding the application of Lorentz transformations. The discussion also highlights limitations in understanding the relationship between mass, energy, and spacetime curvature.
Brucezhou
The problem has been shown in the picture. Because of relativity, both the guys on the ground and on the vehicle would observe length contraction. So the destination of the guy on the vehicle---the galaxy, would be more closed to him. If the vehicle is replaced with the light, which means the distance between the photons and the galaxy would be 0 based on the formula of Lorentz's Transformation. But if this was possible, we can't measure the c=3000000000m/s, since the light can reach where we are immediately without time passes.Personal Explanation1:
To solve such problem, I think the key is that photons do not have mass. So when the they speed up to c, their mass is still 0. Based on General Theorem Of Relativity, the space will not warp and no time dilation will be observed.
To solve such problem, I think the key is that photons do not have mass. So when the they speed up to c, their mass is still 0. Based on General Theorem Of Relativity, the space will not warp and no time dilation will be observed. View attachment 64204
Agreeing with the above poster, but to clear up another misconception, time dilation isn't due to the warping of spacetime but rather to the Lorentzian character of flat spacetime.
Ok, thanks
In GR, spacetime curvature is "caused" by energy and momentum, via the stress-energy tensor. Mass is only one form of energy. Photons do not have mass, but they do have energy and momentum, therefore they can create spacetime curvature.
Hi Bruce:
Any photons must travel at 'c' in the local frame. Also, the Lorentz transform only applies where relative speed between frames [observers] is less than 'c'. edit: in the absence of gravity...no curvature of spacetime...
the speed of light is always 'c'..never 'instantaneous'...
as already posted, that is correct.
So when the they speed up to c...
photons always move at 'c' in free vacuum space...So, for example, a photon emitted from an electron orbital begins at speed 'c'...and stays that way.
But how to explain that phenomenon
John Wheeler explains it this way:
Mass+ tells spacetime how to curve; spacetime tells mass how to move."
+ ...or energy or momentum
careful here ...gravitational time dilation exists:
Two things affect the relative passage of time for different observers: relative speed as in special relativity [and associated length contraction] and in GR, relative gravitational potential.
So in GR, for example, a clock in the bottom a building ticks more slowly relative to a local clock in the top of the building.
http://en.wikipedia.org/wiki/Hafele–Keating_experiment#Gravitational_time_dilation
No scientific theory explains anything. GR is like a good map, it helps us move about in a terrain and predicts what we will see at different places. It is not trying to explain anything.
I could give you a good explanation of why water boils in terms of atoms, heat, and so on. But then you could ask me to explain 'atoms' and we're back to square one.
  • · Replies 45 ·
  • · Replies 52 ·
  • · Replies 36 ·
  • · Replies 83 ·
