Problem involving the human body and rate of heat transfer
The discussion focuses on estimating the net rate of energy loss by radiation from the human body to the night sky. The correct equation for radiative heat transfer is identified as Q/Δt = eσAT^4, with specific values provided: area (A) is 1.8 m², emissivity (e) is 0.97, and Stefan-Boltzmann constant (σ) is 5.67 x 10⁻⁸ W/m²K⁴. The temperatures used are the body temperature of 30°C (303K) and the sky temperature of -40°C (233K). The final calculated energy loss is 543W, which was initially reported as incorrect due to potential miscalculations in the area facing the sky.
  • Understanding of radiative heat transfer principles
  • Familiarity with the Stefan-Boltzmann law
  • Knowledge of temperature conversion between Celsius and Kelvin
  • Basic skills in algebra for solving equations
  • Research the Stefan-Boltzmann law and its applications in thermal physics
  • Learn about emissivity and its impact on radiative heat transfer
  • Explore the concept of net heat transfer and how to calculate it
  • Investigate the effects of surface area orientation on heat loss
Students studying thermodynamics, physics enthusiasts, and professionals in fields related to thermal energy management or environmental science.
chinnie15
If you lie on the ground at night with no cover, you get cold rather quickly. Much of this is due to energy loss by radiation. At night in a dry climate, the temperature of the sky can drop to -40°C. If you are lying on the ground with thin clothing that provides little insulation, the surface temperature of your skin and clothes will be about 30°C.
Estimate the net rate at which your body loses energy by radiation to the night sky under these conditions.
Hint: What area should you use?
Q/Δt=(kA/L)ΔT
So far, I have looked up the k of skin is .50W/mK. I also have the change of temperature, converted to Kelvin, as being 70K. What I have no idea of, though, is what to use for Length and Area? I am not getting the 'hint', lol. It's bugging me because I know how to solve it, I just need to figure out what to use for these values?
Any help would be amazing!
Thank you!
Brittney
You are trying to use the equation for conductive heat transfer to solve a problem which involves radiative heat transfer. Look up the equation for radiative heat transfer.
Oh geez, can't believe I did that. Thanks! So, the equation I need is: Q/Δt=eσAT4
Area, I found out is 1.8m2, e is .97, and σ is 5.67x10-8W/m2K4
My question is... what is T? Is it the temperature of the surroundings? Of the skin? It doesn't say delta T, so I am assuming it's one or the other?
Thank you!
Brittney
Thank you!
Brittney
There are two terms. The heat leaving is at the body temperature of 30C = 303K. The heat arriving from space is at the sky temperature of - 40C = 233K. You need to calculate the net of these two heat flow rates.
Ok, for 'T' I ended up calculating 5.48x109K. After plugging everything in, I am getting the answer of 543W, but it's telling me it's wrong? What could I still be doing wrong?
If you're lying flat on the ground, how much of your surface area is facing the sky?
Thank you! I got it now!
  • · Replies 22 ·
