Problem Involving Work Required for Stretching Spring
  • Thread starter Thread starter chocolatelover
    Spring Work
3 replies · 5K views
chocolatelover
Hi,
Could someone please help me with this problem?
A spring has a natural length of 20 cm. If a 25 N force is required to keep it stretched to a length of 30 cm, how much work is required to stretch it from 20 cm to 25 cm?
w=lim a to b f(x)dx
work=(force)(distance)
int. from 0 to 10 kxdx=25N
25=[1/2kx^2]0 to 10
25=1/2k(10)^2
25=50k
k=.5
int. from .05 to .10 (.5)xdx
Could someone please tell me if this is correct so far?
Thank you very much
No, its not right. You've almost hit it. You know [tex]F=kx[/tex] Now, you know 25N force is required to hold it at 30 cm. Plug these values in and find k from here. Be careful about the unit and convert everything to SI before plugging the values in.
The second part asks you to find the work done, you know [tex]W=\int F(x)dx[/tex].
This gives you [tex]W=\frac{1}{2}kx^2[/tex] Apply the limits as you did, and use the value of k found above, and you have your answer.
Thank you very much
Would the limit be from 0 to 10?
Also, I was thinking that maybe I should have used the formulas f/d=k and w=1/2kd^2
Would that also work, since the force isn't constant?
Thank you very much
Does this look right?
.30-.20=.10m
f(.10)=25
k=250m
.25-.10=.15
.20-.10=.10
w=int. .10 to .15(250xdx)
=1.56J
Thank you very much
