Problem with the Laguerre polynomials
The discussion centers on deriving the first three Laguerre polynomials using a power series approach and the generating function method. Participants debate whether to use the Rodrigues representation or the generating function, ultimately favoring the latter for generating the polynomials. The normalization condition involving the Kronecker delta is highlighted as crucial for establishing the orthonormality of the Laguerre polynomials in quantum mechanics. A participant expresses confusion about the normalization constant after computing integrals for specific values of n, prompting suggestions to explore further integrals for patterns. The conversation emphasizes the importance of these polynomials in representing quantum states.
Logarythmic
My task is to explicitly write down the first three Laguerre polynomials by using a power series ansatz.
What should this ansatz look like? Should it be the Rodrigues representation
L_n (x) = \frac{e^x}{n!} \frac{d^n}{dx^n} x^n e^{-x}
Sounds to me like they either want you to solve the DE using the method of series solutions (see, e.g., Chapter 12 of Boas' Mathematical Methods for Physicists) or that they want you to generate the polynomials from a power series of the generating function (see (19) & (20) here).
I guess it should be the method with the generating function
g(x,z) = \frac{e^{- \frac{xz}{1-z}}}{1-z} = \sum_{n \geq 0} a_n L_n (x) z^n
but how do I get rid of the z?
Taylor expand the generating function in powers of z and the coefficients of the z^n are the Laguerre polynomials. The additional factor of a_n is present because Wolfram is using a definition of the Laguerre polynomials that does not include the 1/n! term in your definition, so you should absorb that a_n term into the L_n for your purposes.
Yes, I got the correct answer. The second part of the exercise tells me to use the normalization
<y_n|y_m>_{e^{-x}} = \int_0^\infty e^{-x}y_n(x)y_m(x)dx = \delta_{nm}
to determine the overall constant.
What constant?
The \delta_{nm} is 1 if n=m and 0 otherwise. So if you perform that integral with n=m the result you get should be equal to one. Using this condition will allow you to determine the normalization constant for the polynomials (i.e. what you have to multiply L_n by in order to satisfy the equation).
This Kronecker delta property is extremely important when using the Laguerre polynomials as an eigenbasis for quantum mechanical states. It allows us to think of the set of Laguerre polynomials as an orthonomal vector space which we can then use as an eigenbasis to represent wavefunctions. The integral you're computing is the dot product between the basis vectors in the Laguerre polynomial space.
Yes I'm aware of all this, but if I solve the integral I get:
For n = m = 0 and n = m = 1, I = 1.
For n = m = 2, I = 2.
Where is the overall constant in this case?
You should do the integral for arbitrary n and see what you get. Alternatively you can try doing it for a few more specific values of n and see if you notice a pattern.
Thanks for your help!
  • · Replies 21 ·
