Problem with the positive orientation of a surface (Stokes' theorem)
The discussion centers on the correct application of Stokes' Theorem, specifically regarding the orientation of the normal vector (N) of a surface and its relationship to the right-hand rule. Participants clarify that the normal vector's orientation is determined by whether it forms an obtuse or acute angle with the positive z-axis, depending on the surface's orientation. Misunderstandings about the right-hand rule and the nature of the curves forming the boundary of the surface are addressed, emphasizing the importance of correctly applying the rule to determine the normal direction.
  • Understanding of Stokes' Theorem and its applications
  • Familiarity with vector mathematics, specifically normal vectors
  • Knowledge of the right-hand rule for determining vector orientations
  • Basic concepts of surface integrals and curl in vector calculus
  • Study the application of Stokes' Theorem in various contexts
  • Learn about vector orientations and their implications in calculus
  • Explore the concept of unit vectors and their role in vector analysis
  • Investigate common misconceptions related to the right-hand rule in vector calculus
Students of mathematics, particularly those studying vector calculus, educators teaching Stokes' Theorem, and anyone seeking to clarify the application of the right-hand rule in relation to surface integrals.
Amaelle
look at the image
stockes theorem
Greetings
the solution is the following which I understand
I do understand why the current orientation of the Path is positive regarding to stocks (the surface should remain to the left) but I don´t understand why the current N vector of the surface is positive regarding stockes theorem
thank you!
Likes Delta2
Amaelle said:
Homework Statement:: look at the image
Relevant Equations:: stockes theorem
Greetings
thank you!
First off, the name is Stokes, not stockes and not stocks. The theorem is Stokes' (or Stokes's) Theorem, AKA Kelvin-Stokes Theorem.
Regarding your question, "I don´t understand why the current N vector of the surface is positive" -- I'm not sure what you mean by N being positive. Numbers can be positive or negative or zero, but vectors aren't comparable to numbers.
The problem statement, "the normal versor of ##\Sigma## forms an obtuse angle with the fundamental versor of the z-axis." I interpret this to mean that N is the vector that makes an obtuse (> 90°) angle with the positive z-axis. That means that N points outward and down, as shown in the drawing. A normal vector that pointed inward and up would make an acute angle with the positive z-axis.
What I find really interesting in this problem is the surface and its boundary. More specifically the boundary ##\partial\Sigma## consists of two closed curves and not just one.
Likes Amaelle
If you want a single closed curve you can add and subtract a curve going from one to the other.
I think the problem usually with surface is if the normal vector will be taken positive as inwards or outwards. For this particular surface, if it is taken positive as inwards, then it makes an acute angle with z-axis, if it is taken positive as outwards, then it makes an obtuse angle with the z-axis. But ok now I see @Mark44 already did a similar comment.
Btw haven't heard the term "versor" before, from the context I think its synonym to "unit vector".
I had to look it up as well. Apparently it was coined by William Rowan Hamilton. Some sources make the claim that Hamilton also coined the word vector to describe the (i, j, k) part of a quaternion. Other sources cite earlier uses of the word "vector."
Likes Delta2
in the case of one simple surface the direction of the path determine the orientation of the surface with the right hand rule, in this case we have two borders if one gives us a surface with an orientation that goes with N and the second with one negative with N I hope you got my point
If that is the case then the curves do not form the directed boundary of the surface and you cannot apply the curl theorem.
Edit: … and note that this is not the case here. Both curves indicate the same normal direction.
AKA the curl theorem. I prefer this as it avoids confusion with Stokes’ theorem (aka Stokes-Cartan theorem) of which it is a special case.
thank you
you said it´s not the case here
when I apply the right hand rule on curve1 it goes up down when I apply it to curve 2, is there soemthing I'm missing?
Yes, you are applying the right hand rule wrong. You are applying it as if the surface was a disc in the middle of the curve - it is not.
The correct way to apply the right hand rule is to think about grabbing the curve with your right hand with the the thumb on the side the curve is directed towards. Then the normal of the surface is in the direction your other fingers point.
Likes Amaelle
thanks a million for all of you ! you made the pain easier to bear :)
Likes Delta2
Its the pain of gaining new knowledge e hehe
No pain no gain!
  • Love
Likes Amaelle
Pain is weakness leaving the body. :wink:
  • Haha
Likes Delta2 and Amaelle
will keep this in mind thank you :)
  • · Replies 21 ·
