Produce a bifurcation diagram using mathematica
9 replies · 13K views · last reply
jemma
I want to produce a bifurcation diagram using mathematica to represent equilibrium points of p1 using the data obtained from the following code, where pn1, pn2, pn3 are recrusion exquations. i.e. x-axis will be the paramter t (ranging from 0-0.3) and y-axis will be the values of p1 this code produces.
series = {};
For[i = 0, i ≤ 300, ++i, p1sol = Sort[
p1 /. NSolve[{pn1 == 0, pn2 == 0, pn3 == 0} /. t -> i/1000.0, {p1, p2, p3}]];
series = Join[p1series, {Join[{i/1000.0}, p1sol]}]]
Thanks if you can help me.
I've made bifurcation diagrams in Matlab, but I'm not familiar with mathematica's language.
If you want to write it as pseudocode and specifically tell me the issue you're having, I might be able to offer some advice.
In mathematica I can export this as a table so I just have the data. I could use MATLAB to generate the actual plot using these data. Would this be possible? Do you have an example of this?
% a prompt for generating a list
series = {};
%NSolve gives a list of numerical approximations for all of the roots of the polynomial
%equation, (maybe the root function in matlab?)
% /.t this just evaluates the equations at t
% t (plotted on the x-axis) ranges from 0-0.3 (since 300/1000)
%The series is a list of the values of p1 at specific values of t.
%Matlab is relatively simple to plot in. You have a matrix of data, you just rip out vectors from it:
%for instance, a matrix S, with size MxN, you just declare a vector to be a slice of the matrix:
parameter = S(:,n) %the whole row in the nth column becomes a vector called 'parameter')
%Do the same with your stable points, pulling them out of the appropriate row (or column, depending on you shaped your data).
stablepoints = S(:,n+1) %or wherever your stable points are (there's no guarantee it will be n+1, I just mean this as an example)
stablepoints2 = S(:,n+2) %if you have a second set of stable points
%Then to plot, just:
plot(parameter,stablepoints,'*') %the * ensures a point will be plotted. By default, MATLAB will connect the points which is no what you want in a bifurcation diagram.
%If you have more than one vector of stable points you can add:
hold on
%so that it won't clear your last plot and will add any additional plots right into the current figure
plot(parameter,stablepoints2,'*')
plot(parameter,stablepoints3,'*')
%making it look pretty:
title 'this is your title'
xlabel 'bifurcation parameter, r'
ylabel 'stable points'
%Is this what you're asking for?
Hi, just one more question... I want to adjust the line width to make it more clear. From what I've read online it suggests the code would look something like this...
plot(parameter,stablepoints2,'*', 'LineWidth', 2)
Is this right? I've tried lots of different line width points but it doesn't seem to be working.
Also, I'd like to plot each set of points in a different colour?
Thanks again!
For colors:
plot(x,y,'r*')
would be a red star
on my iPhone, would have to research the other question on matlab, maybe tomorrow.
So I'm not haveing any problems with that 'LineWidth' line. It thickens the line and plots it. Maybe if you post your code and the error I can trouble shoot.
type 'doc LineSpec' at the MATLAB command line for the color and marker shape codes (i.e r is red, k is black, etc.)
I would also suggest using 'doc' instead of 'help' in general when you're first learning a command.
