How Do You Compute the Expression E = AB - B^*A^* with Complex Numbers?
The expression E = AB - B^*A^* can be computed directly as stated, without the necessity of conjugating either factor. The discussion clarifies that while one can conjugate either A or B, or both, the specific context of the problem dictates the approach. For example, substituting A = 2+3i and B = 4+7i yields different results for each variation of the expression. Ultimately, the interpretation of A and B as complex numbers leads to a clear understanding of the expression's evaluation.
  • Understanding of complex numbers and their properties
  • Familiarity with complex conjugates
  • Knowledge of scalar functions in complex vector spaces
  • Basic algebraic manipulation of complex expressions
  • Study the properties of complex conjugates in depth
  • Learn about complex vector spaces and their applications
  • Explore the implications of scalar functions in physics and engineering
  • Investigate different contexts where complex expressions are utilized
Mathematicians, physicists, and engineers who work with complex numbers and require clarity on the evaluation of expressions involving complex conjugates.
TheCanadian
If I have 2 complex numbers, A and B, what is the correct way to evaluate this expression:
## E = AB - B^*A^*##
I was under the impression that when taking the product of complex numbers, you always conjugate one factor, but in this instance, it is quite important which one is conjugated, no? For example, is the correct way to compute E:
## E = AB^* - BA^*## or ## E = A^*B- B^*A## or another method?
The correct way to calculate ##E## is to calculate the RHS as it is.
I was under the impression that you mixed the ordinary product between complex numbers with an inner product on a complex vector space.
Why do you want to change the expression?
You evaluate AB.
You evaluate B* and A* and multiply them to get B*A*.
You subtract both.
Using some rules for complex numbers you can save a bit of time, but that is completely optional.
There is no "correct way". You can multiply complex numbers without conjugating either one, or you can conjugate one of them, or you can conjugate both of them. It depends what you are doing. Each of the three expressions you have written for E is different from the other two. For example, if:
A = 2+3i
B = 4+7i
Then your first expression for E is 52i, your second expression for E is -4i, and your third expression for E is 4i.
A = 2+3i
B = 4+7i
Thank you for the responses. The main reason I was asking was because I saw the initial expression I posted in a paper but wasn't exactly sure how the author intended the expression to be evaluated.
Then you have to know in which context the equation is presented, e.g. what do those alphabets symbolize, are they scalars, vectors, or linear transformation?
If A and B are complex numbers, the notation has a clear, single meaning.
Ahh yes, I think I confused the exact computation because A and B are the complex amplitudes (scalar functions dependent on the spatial and temporal variables) of complex vectors, but are not vectors themselves. And so in such a case, just to confirm, the expression E above would be computed as initially stated?
## E = AB - B^*A^*## is computed as ## E = AB - B^*A^*##.
  • · Replies 0 ·
  • · Replies 21 ·
