Product of two complex numbers = 0
The discussion centers on proving that for two complex numbers z and w, if their product zw equals zero, then either z or w must be zero. The participants explore the use of exponential polar form, represented as z = re^{iθ} and w = qe^{iφ}. The conclusion is that since e^{i(θ + φ)} cannot be zero, it follows that either r = 0 or q = 0, leading to the definitive result that either z = 0 or w = 0, based on the zero-product property.
  • Understanding of complex numbers and their properties
  • Familiarity with exponential polar form of complex numbers
  • Knowledge of the zero-product property in algebra
  • Basic concepts of absolute values in complex analysis
  • Study the properties of complex numbers, focusing on their polar representation
  • Learn about the zero-product property and its implications in different number systems
  • Explore the concept of modulus in complex analysis and its applications
  • Investigate the implications of complex exponentials in mathematical proofs
Students of mathematics, particularly those studying complex analysis, algebra, and anyone interested in understanding the properties of complex numbers and their applications in proofs.
vesu
Let z and w be two complex numbers such that zw = 0. Show either z = 0 or w = 0.
Hint: try working in exponential polar form
z = re
I have absolutely no clue.
What happens if you write two complex numbers in polar form, then multiply them together and require the result is equal to zero? So z=re^{i\theta}, w = qe^{i\phi},zw = ?
Have you tried that yet? What does the question look like in exponential polar form?
so zw = re^{i\theta} \times qe^{i\phi}
and since neither re^{i\theta} or qe^{i\phi} can be negative, either z = 0 or w = 0. Is this correct?
Not in the slightest. Does negative mean anything when it comes to complex numbers? Also, when imaginary exponents are involved, e^{a+b\cdot i} can be anything. Basic identities about exponents, one of which should be screaming at you, still apply.
Correct, except what does them being negative have to do with anything?
Edit: what I mean is, correct answer, totally wrong reasoning.
Right, whoops. So either z = 0 or w = 0 because of the zero-product property? i.e. "if ab = 0, then either a = 0 or b = 0"? Why is working in exponential polar form at all necessary or even helpful then? :S
rqe^{i(\theta + \phi)} ?
and then since e^{i(\theta + \phi)} > 0 either r=0 or q=0, therefore either z = 0 or w = 0 ?
It certainly can be smaller than 0, but can it be exactly 0?
vesu said:
Right, whoops. So either z = 0 or w = 0 because of the zero-product property? i.e. "if ab = 0, then either a = 0 or b = 0"? Why is working in exponential polar form at all necessary or even helpful then? :Srqe^{i(\theta + \phi)} ?
Oh yeah, so it should be e^{i(\theta + \phi)} \not= 0 then?
I think it's all correct other than that, right?
The point is that we already know it works for reals. Let's assume it works for reals. Now prove it works for complex numbers. Relying on what you're trying to prove won't get you anywhere. If you really do need a hint,
Ever heard of the absolute value function and how it works on complex numbers?
z = re
You can also do it directly: if z = x + i*y and w = u + i*v with x,y,u,v real, then
zw = (xu - vy) + i*(xv + yu), so we need xu = vy and xv = -uy. You can consider several (easy) cases such as u =/= 0 vs, u = 0, and so conclude that in the first case you *must have* x = y = 0, while in the second case you have either v = 0 (so you are done) or else you have x = y = 0.
RGV
I'm a little confused, could you explain how this is incorrect?
zw = 0
zw = rqe^{i(\theta + \phi)}
\therefore r=0 or q=0
\therefore z = 0 or w = 0
I guess you could also do it this way to eliminate i altogether so that you're only working with reals? This doesn't involve exponential polar form though so I'm not sure if this is how we're expected to solve it.
z = a + ib
w = c + id
|zw| = |z||w| = 0
\sqrt{a^2 + b^2} \times \sqrt{c^2 + d^2} = 0
\therefore a and b = 0
or c and d = 0
If z = 0, you are done. Suppose z \neq 0. Then, the multiplicative inverse of z exists. But, then:
<br /> w = \frac{1}{z} \cdot 0 = ?<br />
This has confused me even more. :S
also I cringe every time I re-read this:
I was very very tired. :frown:
It's this step. To justify it, we need to rely on the very identity we are trying to prove, resulting in circular reasoning. Hint: find some way to introduce an absolute value into this equation.
Because this is what you are being asked to prove! That is, you are asked to prove that the "zero product property" holds for complex numbers as well as real numbers.
and then since e^{i(\theta + \phi)} &gt; 0
NO! This not true. For example, e^{i\pi}= -1. But, as you were told before, there is no "less than" or "larger than" relation on the complex numbers.
It is, however, true that e^{ix}, for x real, is never 0.
Uh... I understand what you're saying about what's wrong with my proof but I really don't know what to do even with the hint. :confused:
I mean I know r = |z| and q = |w| so rq=|zw| but I don't know where that gets me.
Try taking the absolute value of both sides.
I gave you an alternative suggestion in my previous posting. Have you looked at it? Have you tried to complete the argument I gave?
RGV
It's not circular reasoning. It's safe to assume here that for real numbers x and y, that xy=0 implies that x=0 or y=0, and this is what the proof is relying on as r and q are both real numbers. The OP is being asked to show the same property holds for complex numbers.
Well, the step I was quoting assumes that, for some real numbers r, q, and ##\psi##,
$$r\cdot q\cdot e^{\psi\cdot i}=0$$
and says that
$$r = 0\lor q = 0\lor e^{\psi\cdot i}=0$$
As ##e^{\psi\cdot i}## isn't necessarily real, this step's invalid. There are a few ways, however, to proceed from here. My favourite is taking the absolute value of both sides, but one could also write ##e^{\psi\cdot i}## as ##a+b\cdot i## for real numbers a and b and work from there.
But vesu didn't do that. Vesu noted the exponential isn't 0, which means it could be divided it out, leaving rq=0.
I'm confused too. In the OP's proof, the claim that the complex exponential factor cannot be 0 seems sufficient. We're you looking for the OP to say explicitly that:
|exp[i(theta + phi)]|
= |1*exp[i(theta + phi)]|
= 1
And therefore the complex exponential part can never be 0, because it must lie on the unit circle in the complex plane?
Would it be valid then to reason that
zw = 0
case 1: z≠0
divide by z
∴w = 0
case 2: w≠0
divide by w
∴z = 0.
case 3: w=z=0
0*0 = 0.
RGV
Sorry, I'm not really sure what to do with your suggestion and I'm still trying to figure out if either of the proofs I have is correct!
Is this proof okay if the other one isn't? (even though this doesn't involve exponential polar form, that was only a hint, not a requirement)
let z = a + ib and w = c + id
zw = 0
|zw| = 0
|z||w| = 0
or c and d = 0
Thoroughly confused at this point. :confused:
vesu said:
|zw| = 0
|z||w| = 0
This step is what you want to prove.
Is it? I was just using |zw|=|z||w|, I don't think that's what we're trying to prove. :S
It is. That's what the whole brouhaha has been in this thread :) Think about it for a while!
zw = 0
case 1: z≠0
divide by z
∴w = 0
case 2: w≠0
divide by w
∴z = 0.
case 3: w=z=0
0*0 = 0.
If you know, for example, that ℂ is a field, then yeah, this works. Dickfore suggested this method earlier in the thread.
Actually, it isn't, which is Whovian's point. Since we're trying to prove that there are no zero divisors, so we can't assume that just because e≠0, then ze=0 implies z=0 because e might be a zero divisor. You should show how to get rid of the complex exponential, e.g. take the modulus or multiply by e-iθ.
Now I agree that the OP was likely using circular reasoning while the rest of us glossed over it, thinking "Obviously you can get rid of the exponential." It was a good catch by Whovian.
  • · Replies 18 ·
