Product of two Kronecker delta symbols as a determinant
The discussion centers on proving the equation involving the product of two Kronecker delta symbols as a determinant. The participants emphasize the importance of pairwise distinct indices for both sets, specifically focusing on the indices i, j, k and p, q, r. They conclude that due to the antisymmetry of the determinant and the Kronecker delta, it suffices to verify the identity for a specific choice of indices, such as (i=1, j=2, k=3) and (p=1, q=2, r=3). This approach simplifies the proof process without needing to evaluate all possible combinations.
  • Understanding of Kronecker delta symbols
  • Familiarity with determinants in linear algebra
  • Knowledge of antisymmetry properties in mathematical expressions
  • Basic combinatorial reasoning
  • Study the properties of Kronecker delta symbols in detail
  • Learn about determinants and their expansion techniques
  • Explore antisymmetry in mathematical proofs and its implications
  • Investigate specific examples of determinants with distinct indices
Mathematicians, physics students, and anyone interested in linear algebra and tensor analysis will benefit from this discussion, particularly those looking to understand the implications of Kronecker delta symbols in determinants.
brotherbobby
The books says that "it is fairly easy" to verify the following product of two kronecker delta symbols : ##\epsilon_{ijk} \epsilon_{pqr} = \begin{vmatrix} \delta_{ip} & \delta_{iq} & \delta_{ir} \\ \delta_{jp} & \delta_{jq} & \delta_{jr} \\ \delta_{kp} & \delta_{kq} & \delta_{kr} \\ \end{vmatrix}##
We know the definition of the krokecker alternating symbol. Here all variables can only take values between 1 and 3. If any of the indices repeat, the value of the symbol is 0. If the indices alternate, the symbol takes on a minus sign.
I don't have a clue as to how to go about proving (or verifying) the equation above. It would be very hard to take individual values of i,j and k and p,q and r for each side and evaluate ##3^6## times! More than that, I'd like a proof more than a verification.
Any help would be welcome.
Both sides vanish if any two of ##i,j,k## or any two of ##p,q,r## are equal (the LHS is zero since a LC symbol with repeated index is zero, and the RHS is zero because two columns or two rows will be equal).
So we're in the case that ##i,j,k## and ##p,q,r## are pairwise distinct. Since both sides are anti-symmetric under changing two indices from either set, it's enough to check that your identity is true for just one particular choice of indices, say ##i=1, j=2, k=3## and ##p=1,q=2, r=3.## You should think about why this is sufficient if it's not obvious at first.
You can probably also expand the determinant, but I find this way of thinking to be simpler.
I have got your answer mostly, except your quote above. It is not obvious to me as to why should the values of ##i, j \,\text{and}\, k## and those of ##p,q\, \text{and}\, r## be those as you said : 1, 2 and 3. Why not 2, 3 and 1, respectively, for example?
It follows from the antisymmetry of both sides. Changing ##(i,j,k)=(1,2,3)\to (2,1,3)\to (2,3,1)## changes both ##\varepsilon_{ijk}\varepsilon_{pqr}## and your determinant by a factor of ##-1## twice, and hence leaves them unchanged.
12K
