Projectile montion Problem given the Inital Velocity and Angle to horizontal
The discussion revolves around a projectile motion problem involving a football kicked at an angle of 32.5 degrees with an initial velocity of 42 m/s. The original poster seeks assistance in determining the ball's velocity and acceleration vector at maximum height, while assuming negligible air resistance.
  • Participants discuss breaking down the initial velocity into vertical and horizontal components and question the necessity of previously calculated values for solving the current parts of the problem. There is also a focus on understanding the implications of neglecting air resistance.
The conversation is ongoing, with some participants providing guidance on the approach to take. There is recognition of the original poster's confusion, and others are encouraging further exploration of the problem without reaching a consensus yet.
The original poster expresses uncertainty about their calculations and acknowledges their inexperience in physics, which may influence their understanding of the problem. There is a mention of the need for clarification on the basic principles of projectile motion.
keithc
Hi All,
I am struggling to work out the following:
Q: A football is kicked at an angle of 32.50 to the horizontal, with an initial velocity of 42m/s. Assume air resistance is negligible.
A) Find the Balls Velocity at max Height
B) The Balls Acceleratoin Vector at max Height
I have so far worked out the following:
The balls Max height has worked out to be 25.68 m
The Travel time is 8.57 s
and the Distance traveled is 303.5494m
But not sure where to go with this next to figure out the A) and B) parts.
I would very grateful for any help on this.
Thx, K
If the method of solution is shown one can give help in a more suitable way.
You don't need any of the 3 things you have figured out in order to get the 2 that you need. In fact, the 3 that you have figured out are quite a bit more complicated then the 2 you are asking about. You are WAAYY over thinking it.
Hi All, thanks for looking and inputs. I am new to physics hence I have probably asked a silly question. But if don't ask I will never learn..
Thx again, K
So did you figure it out?
Not yet ! Still hitting my head of this ball.. hehe.. I am lost as to where to go with my calc's. If I do I will post how I got there hopefully!
Start by breaking your initial velocity down into vertical and horizontal components. What is factors are going to influence each component while the football is in flight?
I think I have worked out the velocity at the max height. Not too sure if I am correct or not.
The vertical velocity is 0 so that means that the horizontal velocity worked out by
42. cos 32.5 degs= 35.422 m/s is the same as the velocity at max height or am I totally off with this??
Thx K
Right on. Now the acceleration question is the easiest of all. Since we are neglecting air resistance there is only one other force to consider...
10K
27K
