Projectile Motion and Speed: Solving for Initial Velocity and Height
The discussion revolves around solving a projectile motion problem involving a frog that jumps from a log, landing 2.80 m away after 2.5 seconds at a 40-degree angle. The initial speed of the frog was calculated to be approximately 1.4621 m/s, with a vertical component of about 0.9398 m/s. The height from which the frog jumped was determined to be around 28.28 m, raising concerns about the realism of such a height for a log. Participants noted that while the height seems excessive, the calculations align with the physics of projectile motion. The original poster expressed satisfaction with the problem-solving process, indicating success in their exam.
dano404
[SOLVED] Projectile Motion Problem
A frog jumps from a log and lands on the ground a distance of 2.80 m away. The frog is airborne for 2.5 seconds, and leaves the log at an angle of 40 degrees. (a) What was the frog's speed (vo) just after it jumped? (b) How high above the ground did the frog jump from?
The equations I used:
<br /> y = y_0 + v_0_yt - (1/2)g(t^2)<br />
<br /> x = x_0 + v_0_xt<br />
First I found that
<br /> v_0_y = v_0sin(40)<br />
and
<br /> v_0_x = v_0cos(40)<br />
Then,
<br /> 2.8 = 0 + (v_0*cos(40))(2.5)<br />
<br /> v_0 = 1.4621 m/s<br />
Now,
<br /> v_0_y = 1.4621sin(40)<br />
<br /> v_0_y = 0.9398 m/s<br />
Using the first equation,
<br /> 0 = y_0 + (0.9398)(2.5) - (1/2)9.8(2.5^2)<br />
<br /> y_0 = 28.28 m<br />
...Now I really don't think that a frog would be jumping off a 30 meter log. Any ideas at where I'm going wrong?
dano404 said:
First I found that
and
Then,
That looks to be correct.
You could have simply also said that since the horizontal component of velocity stays the same. Distance=Speed*Time.
For the second part. 2.5 seconds is the time for the frog to complete its parabolic motion. Which means that t=2.5 isn't the time at maximum height.
Hmmm, I still seem to be getting the same answer.
Using:
<br /> v_y = v_0_y - gt<br />
<br /> 0 = 0.9398 - (9.8)t<br />
I found that it takes roughly 0.06 seconds for the frog to reach the highest point in the jump leaving 2.4 seconds of freefall.
<br /> y = y_0 + v_0_yt - (1/2)gt^2<br />
<br /> 0 = y_0 + (1/2)(9.8)(2.4^2)<br />
Which still gives me a height of about 28m.
Whoops...that last post calculated the maximum height reached, not the height at which the little bugger started from. I'm not really sure why I couldn't use 2.5s as the time like I did before.
Hi dano404,
The work in your original post looked okay to me. Was the large height not sounding right? I do understand that a log 30 meters in the air sounds strange, but the numbers they give seem consistent with your answer. Think about the time of flight and what it does to the y velocity. If the frog had just dropped off, after 1 second it would be going about 10 m/s, after 2 seconds it would be traveling about 20m/s, etc., so traveling about 30 m in 2.5 seconds sounds reasonable, I think. (The frog is traveling upwards at the beginning in this problem, but the initial y-velocity is relatively small so these approximate values are still close.)
The poor frog may not enjoy the landing, but collisions are another problem.
My professor had accidentally made a typo when writing the problem (on a test from a previous course). He typically tends to make things very realistic which is why I was surprised by the result. Thank you for the responses. I just took my exam, definitely aced it.
