Projectile Motion Bullet Shot Help
8 replies · 5K views
yogoes123
bullet shot horizontally over level ground with a velocity of 300m/s. at the instant that the bullet leaves the barrel, its empty shell casing falls vertically and strikes the ground with a vertical velocity of 5.00m/s
how far does the bullet travel
what is the vertical component of the bullet's velocity at the instant before it his the ground?
I tried a bunch of stuff and I didnt get the right answer, can someone just point me in the right direction? Please, at least tell me which equation to use cause I can't figure this out.
Hi yogoes123. Is there a question attached to this statement?
sorry i somehow missed that, very sorry i edited it.
Same here. I can't figure out which equation to use until I have condensed that wordy statement into something that looks more mathematical.
First thing, write down all the information that you know, expressing it as values of variables, e.g.,
bullet: vi = 300 m/sec
casing: vi = ?
    vf = ?
etc.
Ok guys i think there is a bit of confusion. The question says the bullet has a horizontal velocity of 300 m/s.
They want you to find range.
They also say the bullet shell falls vertically at a rate of 5 m/s, not sure why but its probably needed.
Thats all they give u.
Horizontal Velocity of bullet: 300 m/s
Vertical velocity of SHELL: 5m/s
A sharpshooter shoots a bullet horizontally over level ground with a velocity of 3.00 x 10^2 m/s. At the instant that the bullet leaves the barrel, its empty shell casing falls vertically and strikes the ground with a vertical velocity of 5.00 m/s
a) How far does the bullet travel
b) What is the vertical component of the bullet's velocity at the instant before it hits the ground.
yogoes123 said:
bullet shot horizontally over level ground with a velocity of 300m/s. at the instant that the bullet leaves the barrel, its empty shell casing falls vertically and strikes the ground with a vertical velocity of 5.00m/s. So if you want to find the distance it traveled, you need to find ow far it traveled in x and in y.
Break this down into your knowns and unknowns.
You only have four kinematic equations.
This problem is a projectile problem that is asking you to break things up in terms of x and y. First the shell moves initially with the bullet at 300 m/s horizontally, and then when it approaches 0 m/s, due to gravity it accelerates vertically at 9.8 m/s2 towards the Earth to reach a final velocity of 5 m/s.
So what do you know?
Horizontal Movement
Vix= 300 m/s
t=(5m/s)/(9.8m/s2)=0.5097s
ax= 0 m/s2
Δx=?
Δx=(vix)(t) + (0.5)(ax)(t)2
Vertical Movement
viy= 0 m/s
vfy= 5m/s
ay= 9.8 m/s2
Δx=?
vfy2 = viy2 + (2)(ay)(Δy)
