Projectile Motion: Calculating Speed of Ball Thrown from Third Floor Window
The problem involves projectile motion, specifically calculating the speed of a ball thrown downward from a third-floor window at an angle. The scenario presents a height of 12 meters and an initial speed of 25.0 m/s at a 45-degree angle.
  • Participants discuss breaking down the initial velocity into horizontal and vertical components and question how to apply these in the context of the problem. There is confusion regarding the use of kinematic equations and the role of acceleration due to gravity.
Participants are actively engaging with the problem, questioning the initial conditions and the relevant kinematic quantities. Some guidance has been offered regarding the distinction between vertical and horizontal components of velocity and the implications of the angle of projection.
There is an ongoing discussion about the assumptions related to air resistance and the need for clarity on the initial velocity in the vertical direction. Participants are also considering which kinematic equation might be appropriate for finding the final velocity without focusing on time.
Brainiac11
<< Thread moved to the HH forums from the technical physics forums, so no HH Templatge is shown >>[/color]
So I have this question that says, "Someone at a third floor window (12 m above ground) hurls a ball downward at 45 degrees at a speed of 25.0 m/s. How fast will it be traveling when it strikes the sidewalk?"
I broke it up into horizontal and vertical components, but I don't know where to use them in solving for it. I tried to use the equation Yf=Yi+Vi(t)+(1/2)(a)(t)^2 but then I got confused. I feel like the question is asking me for an acceleration but I thought the acceleration in all projectile motion questions was -9.8 (gravity). So if I use the equation I was wanting to I would have put: Yf=0, Yi= 12, Vi=-25.0, and a=-9.8. However, that would have given me time which I don't think is what I'm being asked to find.
I think you should post this in the homework help forum, but I'll leave that for a moderator to relocate.
I guess we should start with what the question is asking. According to the beginning of your post:
So, out of the kinematic quantities (time, displacement/distance, velocity/speed, and acceleration) which are you being asked about?
Speed?
Indeed. Suppose I told you that an object had a velocity of
##<3m/s, 4m/s>##
(note that I am referring to components of a vector). What would be the speed of this object?
Brainiac11 said:
Speed?
Correct:
You know gravity will act in the Y direction which will cause a downward acceleration.
What is the initial velocity in the Y direction? It isn't -25m/s as you've calculated, that would be true if the ball was thrown straight down but it isn't. it depends on the initial angle..
The equation you've used has time as the unknown, but are you interested in finding the time? You have an initial velocity, a distance and an
acceleration and you are looking for the final velocity. Is there is a SUVAT equation to do that?
What can you say about the velocity in the X direction? will it change? (I think it's safe to assume no air resistance acts)
billy_joule said:
Correct:You know gravity will act in the Y direction which will cause a downward acceleration.
Yes! I got it! Thank you all!
  • · Replies 22 ·
