Projectile Motion (Initial Velocity)
The discussion revolves around determining the initial velocity of a ball kicked from point A to clear a wall at point B, focusing on projectile motion principles. The scenario involves a wall height of 4m and a horizontal distance of 20m from the launch point, with participants exploring various kinematic equations and concepts related to vertical and horizontal motion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using trigonometric relationships to find the angle of projection and analyze vertical motion to determine the vertical component of initial velocity. There are attempts to apply kinematic equations, with some questioning the correctness of their approach and the use of average versus initial velocities.
The discussion is ongoing, with participants providing guidance on the use of kinematic equations and clarifying concepts related to average speed and time calculations. There is an exploration of different methods to find time and initial velocity, with no explicit consensus reached yet.
Participants are navigating the complexities of projectile motion, with some expressing uncertainty about the application of formulas and the distinction between average and initial velocities. The discussion reflects a learning process with varying levels of understanding among participants.
Milkster18
Hi, I am trying to find the initial velocity of this question:
Using a video camera, it is observed that when a ball is kicked from A, it just clears the top of a wall at B as it reaches its maximum height. Knowing the distance from A to the wall is 20m and the wall is 4m high, determine the initial velocity at which the ball was kicked. Neglect size of the ball ( Ans Ua = 23.9m/s).
So I am thinking to find the angle you have to use trig :
so 20^2 + 4^2 = square root of 416 = 20.4m (hypotenuse)
using Sin, 4/ 20.4 = Invert Sin 0.196 = 11.3 degrees angle the ball is projected.
Now i have then angle what else do i need to find in order to find the initial velocity at which the ball was kicked?
Thanks for any help
That angle is not the angle of the ball's initial velocity. The ball travels a parabolic trajectory, not a straight line.
Analyze the vertical motion first. Figure out the vertical component of the initial velocity.
Ah ok, i thought about the ball not traveling in a straight line assuming the angle was wrong at some point.
Ok so if 'm trying to analyze the vertical component of the initial velocity I am going to use equation:
Sy = Uyt + 0.5(ay)t^2 Or
Vy^2 = Uy^2 - 2g(Sy)
The 2nd equation I'm thinking i should use since it has just one unknown (Uy).
Vy = 0, Sy = 4m
0 = Uy^2 - 2(-9.81)(4)
I don't want to go further until i know what I'm doing so far is correct..
Vy = 0, Sy = 4m
Almost perfect. You have an extra minus sign in your last equation. g is just the magnitude of acceleration, so g = 9.81, not -9.81. (The acceleration is -g = -(9.81) = -9.81 m/s^2.)
Ok so
Uy^2 = 2(9.81)(4) + 0
Uy^2 = square root 78.48
Uy =8.86 m/s Correct?
What shall i do now?
Do i find the time?
Sy = Uyt + 0.5(9.81)t^
Sy = 4 + (8.86)t - 4.905t^2
Sy = 12.86t / 4.905^2
4 = 12.86 - 4.905
4 = 7.955
t = square root 0.5 = 0.7s
t = 0.7 s .. is this correct so far?
Milkster18 said:
Ok so
Yes. Good.
Do i find the time?
Right approach, but you messed up the equation:
(1) 4 is the final position, not the initial.
(2) a + bt ≠ (a + b)t
Even easier: What's the average vertical speed? Use that to find the time.
Average vertical speed..
Uy / g
8.86 / 9.81 = 0.9 s?
(Sorry I am getting tired as its nearly 2am)
speed is calculating in m/s.. sorry I am confused
Uy / g
No. The vertical speed varies uniformly from its initial value of 8.86 m/s to 0 at the highest point. What do you think the average vertical speed would be?
sice it highest point is Sy = 4m
is it 8.86 / 4 = 2.215 m/s average vertical speed?
if its not can you provide further help? thanks
No. You cannot divide a speed by a distance and expect to end up with a speed.
Try this analogy: You start out making zero money and, uniformly, little by little, end up making $100/day. Over that time period, what was your average salary per day?
You may want to review some of the basic formulas of kinematics:
https://www.physicsforums.com/showpost.php?p=905663&postcount=2"
http://www.physicsclassroom.com/Class/1DKin/U1L6a.cfm"
And here's some good stuff about projectile motion:
http://www.physicsclassroom.com/Class/vectors/u3l2a.cfm"
u+v / 2 = the average?
So v = 0
8.86 / 2 = 4.43 m/s
So v = 0
8.86 / 2 = 4.43 m/s
Good! So now that you have the average vertical speed and the vertical distance, figure out the time.
with the analogy:
Say you made 0$ to 100$ over 7 days .. average income per day is 100 / 7 = 14.3$ per day
Sy = (4.43)t - (4.91)t^2
4 = (4.43)t - (4.91)
4 = -0.48?
4 / 0.48 = square root 8.33
t = 2.887 s ?
Question: Why does the AVERAGE Initial vertical velocity have to be used instead of just the initial vertical velocity so i can understand why?
Milkster18 said:
with the analogy:
No. Your income increases from 0/day to 100/day. Like this:
0/day; 1/day, 2/day, 3/day... 100/day. Average (assuming uniform increase--just like uniform acceleration) is (0 + 100)/2 = 50/day. Half the time you made less, half the time you made more.
(But don't worry about that analogy if it doesn't help.)
4 = -0.48?
t = 2.887 s ?
No, using that method you would use the initial velocity, not the average velocity. You'll end up with a quadratic to solve.
Again, using that method you would use the initial velocity.
I wanted to show you an easier way to get the time, using Distance = ave speed X time. No quadratics to solve. (Do it both ways and compare the answers.)
Yes i realize using quadratics is a way to find time, i didn't know there was an easier way to solve for t thou.
as for getting the average vertical initial velocity .. i don't know what this answer goes into which equation in order to solve t.
Sorry i haven't solved for initial velocity before as this topic (projectile motion) is new to me.
Easier methods are always better :)
solving for Ux i would have to find time t?
You should solve it both ways to make sure you understand them.
I gave you the needed equation in my last post--in words. (Another version is in the first link I gave you.)
You're doing OK. Keep at it!
Yes. To solve for Ux, you'll first need the time. Which is what you're solving for now.
Ok so in order to find t i use:
Ur saying: Distance = avg speed x time
So time = distance / avg speed?
Got 2 distances sy = 4, sx = 20m
Not sure wat to do here..
Im guessing 4 / 4.43 = 0.9s
Or 4.43/4 = 1.11s
Yes.
Since we just found the average vertical speed, you'll use the vertical distance.
Right. (But why guess? Just plug into the formula.)
Or 4.43/4 = 1.11s
That doesn't work. We want distance/speed not speed/distance.
It always helps to check units:
distance/speed = (m)/(m/s) = 1/(1/s) = s (makes sense, since we are trying to find a time)
speed/distance = (m/s)/m = 1/s (no good--1/s is not a proper unit for time)
Ok, sorry i didn't know about distance = avg speed x time formula. Wasn't told by my lecturer about that.
yes distance / speed sounds better than speed / distance lol.
so now i find Ux given by time.
Sx = Ux t
Ux = Sx / t =
Ux = 20 / 0.9 = Ux as 22.22 m/s
so if I am finding average of Ux:
average horizontal initial velocity = 11.11 m/s?
So now i have the horizontal and vertical component, how do i use these to find the initial velocity?
Sx = Ux t
Ux = Sx / t =
OK.
(1) Since there's no horizontal acceleration, the average horizontal speed is the same as the initial horizontal speed Ux. (It doesn't vary from 0 m/s to 22.22 m/s; it's constant at 22.22 m/s.)
(2) Ux is what we want, anyway. (We only used average vertical speed as a means to find the time.)
Ux and Uy are the components of the velocity vector. Use Pythagoras to find the magnitude and some trig to find the angle.
Ok looking good.
Square root 8.86^2 + 22.22^2
=23.9 m/s
Ui = 23.9 m/s .. looking good its correct :)
Any reason to find the angle? I am guessing to help find other components?
If anything ever comes to using quadratic equations is there any other method that is easier such as the average vertical initial component? I've seen quadratic equations involving Sin/Tan/Cos and it looks ever so confusing.
Thanks again Doc Al, before i finish this thread i was just wondering about finding something off topic:
Angular Motion:
Question: A flywheel increases its frequency of rotation from 20rpm to 40 rpm in 10 s with a uniform angular acceleration. calculate a) the angular acceleration, and (b) the number of revolutions made during the 10s period.
Answer to a) is 0.21rad/s^2
b) revolutions is 5 ...
but i don't understand how to calculate how many revolutions in a period of time giving the answer to question (b) above
I can calculate everything else apart from the revolutions because once again i wasn't given a formula or teaching of how to find this. Would you be able to provide information on how to find this ?
Thanks again.
Milkster18 said:
Ok looking good.
=23.9 m/s
Good!
You'd find the angle to fully specify the initial velocity. (If you need to; the question is ambiguous.) You already have the components.
Sometimes there's no way around it and you have to solve a quadratic.
Angular Motion:
The basic equations of motion for rotational motion are exactly analogous to the equations for linear motion. Here the number of revolutions (or the angle) is analogous to distance.
One easy way is to use our average velocity trick to find the distance/revolutions. Careful with units.
Check out this list: http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html#rlin"
So use equation
Pheta = W1 + 0.5at^2
W1 = 2.1rad/s
W2 = 4.19 rad/s
Pheta = 2.1(10) + 0.5(0.21)(10)^2
Pheta = 21 + 10.5
Pheta = 30.5 radians?
How do i use this to find revolutions if this is correct?
31.5 radians.. my mistake
Milkster18 said:
So use equation
W1 = 2.1rad/s
W2 = 4.19 rad/s
Pheta = 21 + 10.5
Good. (Except for the typo, which you corrected later.)
How many radians equal one revolution?
And don't forget to try the 'easy way'. What's the average angular speed in rpm for that interval?
  • · Replies 21 ·
  • · Replies 18 ·
  • · Replies 22 ·
  • · Replies 22 ·
