Projectile motion of half a parabola
The discussion focuses on solving a projectile motion problem involving a ball thrown horizontally from a height of 3 meters at a velocity of 20 m/s. Participants clarify that the time in the air can be calculated using the vertical motion equations, specifically identifying that the initial vertical velocity (Vi) is 0 m/s. The time of flight (t) is determined to be 0.77 seconds, which is essential for calculating the horizontal displacement (Dx) using the appropriate kinematic equations for both the x and y components of motion.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Knowledge of horizontal and vertical motion components
  • Basic algebra for solving equations
  • Study the kinematic equations for projectile motion
  • Learn how to decompose motion into x and y components
  • Explore the concept of free fall and its equations
  • Practice solving similar projectile motion problems
Students studying physics, educators teaching projectile motion, and anyone interested in understanding the dynamics of objects in motion under the influence of gravity.
weesieman
1. I have a ball that is thrown off a 3m high cliff at 20 m/s horizontally, what is the displacement on the X axis, Vf, and tair? (assuming no air resistance)
d=Vi*t+(1/2a*t2
When I tried to solve this problem I couldn't really find an equation that worked. I'm confused about how to find the time in the air with the given information, do you guys know any other formulas that would be helpful for this problem?
The formula you wrote would work. Do you know what are the parameters in it?
You need to think in terms of separate x and y components. The equation you've stated is for the y-component. What is Vi (y direction) in this case? The problem statement tells you. From this you can find t.
Next, you need a kinematic equation for the x direction. It's pretty simple. Think of the forces acting in the x direction. Any guess?
I don't think I can use it because all I really know in that formula is Vi and Acceleration
Vi for Y is 0, so I would need to use the formula to find the time, which is .77 seconds, so with this I can find Dx right?
Yes, but what's the distance equation in the x-direction. Like I said, pretty simple.
I think you know one more thing. Check the known data once more.
  • · Replies 22 ·
  • · Replies 21 ·
