Projectile motion problem: initial velocity calculation
10 replies · 3K views · last reply
UNknown 2010
Hello,
I have solved the following problem but my answer does not matched with the answer which is written in the book. My answer is 32 m/s but the answer of the book is 37 m/s
[PLAIN]http://img842.imageshack.us/img842/6706/projectile.png
Could anyone please show me where my mistake is ?
Thanks =)
I don't get either your answer or the book answer!
Maybe you will see my mistake . . .
I did not trust that v² formula because the signs are complicated: you would get the 32.08 answer regardless of whether the initial velocity was up or down! So for the vertical part I used d = vt+.5gt² with d = -50, v = +7sin(53), g= -9.81 to get that the time to fall is 3.37 s. Then I put that into
Vf = Vi + at = 7sin(53)-9.81*3.37 = -27.5 m/s.
Final answer of 27.8 m/s.
UNknown 2010 said:
Hello,
Could anyone please show me where my mistake is ?Thanks =)
I believe the answer you gave above (your answer) is correct, with possible, minor precision issues. The mistake must be in the book.
i got exactly your answer Unknown 2010, so the book is wrong
and Delphi51 you don't even need to look at time
^^same thing with me...the book seems to be wrong..
You might want to check your numbers again. I got t = 3.813 seconds using your method.
I still don't see it, Collinsmark. Hope you will pinpoint it for me!
-50 = 7*sin(53) - .5*9.81*t²
4.905*t² = 7*sin(53) + 50
4.905*t² = 55.59
t² = 55.59/4.905 = 11.33
t = 3.367
edit - Oops: forgot the t! Now getting the 31.8 m/s for the vertical.
Thank you for sorting that out!
4.905*t² = 55.59
t = 3.367
i honestly don't see how your solution is plausible of working. Can you explain how you take into account the time traveled above 50m?
The t is the time of flight. Those formulas Vf = Vi + at and
d = Vi*t + ½a*t² are for all constant acceleration motion and always account for the time, distance and speed automatically whether above or below the starting point. If you solve the first formula for t and sub into the second, you'll get the Vf² = Vi² + 2ad formula.
UNknown 2010 said:
Hello,
Thanks =)
Your work is perfect, with the minor exception that [tex]v_y[/tex] should be negative since the rock is moving downward at that point. This will also affect your angle. Remember that [tex]\sqrt{x^2} = \pm x[/tex]
okay i see what you did, and why it works
