Projectile motion with linear drag
The discussion focuses on deriving equations for projectile motion affected by linear drag, specifically for vertical and horizontal motions. For vertical motion, the equations for velocity vz(t) and position z(t) are derived from an initial height H with zero initial velocity. In horizontal motion, similar equations for velocity vx(t) and position x(t) are obtained from an initial height H and a non-zero initial horizontal velocity. The combined equations lead to a trajectory equation z(x) and a range equation that quantifies the maximum horizontal distance traveled. The differences between the range with and without drag are highlighted, emphasizing the impact of drag on projectile performance.
ewelinaaa
We consider a projectile motion against a linear drag force D = −b∗v, where v is the velocity
of the projectile.
(A) Suppose only a vertical drop (in z-direction), v = vz, from an initial height H with
an initial velocity voz = 0. Obtain the corresponding equations for (a) velocity vz(t), (b)
vertical position change of the projectile z(t).
(B) Consider now only a horizontal motion (with drag) v = vx, from an initial height H and
with an initial horizontal velocity vox. Obtain the corresponding equations for (a) velocity
vx(t), (b) horizontal position change of the projectile x(t).
Combine the horizontal and vertical equations of motion for a projectile moving against a
linear drag force, see a previous task, to (A) obtain an equation of the trajectory of the
projectile, i.e., z(x). (B) Obtain an equation for the RANGE (i.e., maximum horizontal
distance reached) of the projectile. (C) Compare the range equation with an equation for
range obtained in the case of vanishing drag force. Discuss the differences.
D = −b∗v
ewelinaaa said:
Homework Statement: We consider a projectile motion against a linear drag force D = −b∗v, where v is the velocity
of the projectile.
Homework Equations: D = −b∗v
Per forum rules , please post an attempt.
  • · Replies 18 ·
  • · Replies 38 ·
