Projectile Subject to Quadratic Air Resistance
The discussion focuses on solving the equations of motion for a projectile subject to quadratic air resistance, specifically when thrown vertically upward with an initial speed v0. The correct equation for upward motion is established as m dv/dt = mg - cv², leading to the terminal velocity vter = sqrt(mg/c). The time to reach the peak of the trajectory is derived as ttop = (vter/g)arctan(v0/vter), correcting the initial misunderstanding of using the inverse hyperbolic tangent. The importance of sign conventions in the equations is emphasized for accurate results.
  • Understanding of differential equations, particularly first-order ODEs
  • Familiarity with concepts of air resistance and terminal velocity
  • Knowledge of kinematics and forces acting on a projectile
  • Proficiency in calculus, especially integration techniques
  • Study the derivation of terminal velocity in fluid dynamics
  • Learn about the effects of quadratic drag on projectile motion
  • Explore numerical methods for solving differential equations
  • Investigate the impact of varying mass on projectile motion with air resistance
Students and educators in physics, engineers working on projectile dynamics, and anyone interested in advanced mechanics involving air resistance and motion equations.
Yosty22
A projectile that is subject to quadratic air resistance is thrown vertically up with initial speed v0.
(a): Write down the equation of motion for the upward motion and solve it to give v as a function of t.
(b): Show that the time to reach th top of the trajectory is ttop = (vter/g)arctan(v0/vter.
ma = -cv2
I think I may have done something wrong with part a which is leading me astray for part b.
Part (a):
m dv/dt = mg - cv2
vter occurs when mg = cv2
vter = sqrt (mg / c)
solving for c, I get: c = (mg / (vter)2)
Putting this back into my differential equation and cancelling the mass out:
dv/dt = g(1 - (v2 / vter2))
Integrating both sides, I get:
gt = vterarctanh(v/vter) - vterarctanh(v0/vter)
solving for v as a function of t, I get:
v(t) = vtertanh((gt/vter) + arctanh(v0/vter))
Therefore, for part b, when it is at the top of its flight, v(t) = 0. Substituting in the zero and solving for t, I get:
(vter/g)arctanh(v0/vter)
As you can see, this is almost what the correct answer is, except it should be a function of the inverse tangent of v0 / vter, NOT the inverse hyperbolictangent.
Any ideas where I went wrong or what I am missing here?
Thanks in advance.
Yosty22 said:
m dv/dt = mg - cv2
Be careful with the signs. Strictly speaking, the quadratic drag equation (omitting gravity for now) is m dv/dt = -kv.|v|. This arranges that the drag always opposes the motion.
Alternatively, to eliminate the modulus sign, use different equations for the upward and downward phases.
If we take up as positive and g as therefore having a negative value, the upward equation is as you wrote above, but you'll need the downward equation to get terminal velocity.
Ok, that makes sense, but I am a little confused as to how to create another differential equation for the downward equation. Would I just flip the sign and make it -mg-cv 2 ? The only thing I can think of is to make g negative and keep cv 2 negative since drag always opposes motion. Is that the right idea?
For solving (a) and (b), you just need the equation for upward motion, which is:
<br /> m\frac{dv}{dt} = -mg - cv^2<br />
if the upwards direction is considered positive.
Your procedure from that point on is fine until you try to solve the first order ODE. It would be very helpful (to me at least) if you could show, in detail, how you go about it.
Except that (b) involves "vter", for which you need to consider the downward motion.
which is:
It depends how you define 'g'. My preference is that it is the acceleration due to gravity as a signed quantity, so the upward equation is ##m\frac{dv}{dt} = mg - cv^2##, and the downward is ##m\frac{dv}{dt} = mg + cv^2##, where g has a negative value.
I might have went over the finer points a bit too quickly here. I considered 'g' a positive constant, since that was consistent with the solution given, but I shouldn't impose that on the OP.
I also took vter to mean the magnitude of the terminal velocity.
Got it! Thanks for all of the help! It ended up working out when I fixed the sign issue so that the differential equation represents the upward motion rather than the downward motion. Thank you for all of your help!
  • · Replies 37 ·
