Projectile thrown up an incline, max distance?
The discussion focuses on deriving the maximum range \( R_{max} \) of a projectile thrown up an inclined plane at an angle \( \phi \) with an initial speed \( V \). The maximum range formula is established as \( R_{max} = \frac{V^2}{g(1 + \sin{\phi})} \). Participants clarify the optimization of the angle \( \theta \) for maximum distance, leading to the conclusion that the optimal angle is \( \theta = \frac{\pi}{4} - \frac{\phi}{2} \). The calculations involve trigonometric identities and derivatives to confirm the relationship between the angles and the range.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions and identities
  • Knowledge of calculus, specifically differentiation
  • Basic physics concepts, including force and acceleration (F = ma)
  • Study the derivation of projectile motion equations in inclined planes
  • Learn about optimization techniques in calculus, particularly for trigonometric functions
  • Explore the application of trigonometric identities in physics problems
  • Investigate the effects of varying angles on projectile trajectories
Physics students, educators, and anyone interested in understanding projectile motion dynamics, particularly in inclined scenarios.
sabinscabin
A ball is thrown with initial speed V up an inclined plane. The plane is inclined at an angle \phi above the horizontal, and the ball's velocity is at an angle \theta above the plane.
Show that the ball lands a distance R = \frac{ 2V^2 \sin{\theta} \cos{ ( \theta + \phi} ) } { g \cos^2{\phi} } from its launch point. Show that for a given V and
\phi, the maximum possible range up the inclined plane is
R_{max} = \frac{ V^2 }{ g (1 + \sin{\phi} )}
F = ma
I calculated the distance traveled up the incline fine. However, I'm having trouble proving the second part. I'm guessing I'm supposed to maximize R with respect to theta, so from the equation above we have:
\frac{d} {d \theta} \sin{\theta} \cos{(\theta + \phi)} = 0
\cos{( 2 \theta + \phi )} = 0
\theta = \frac{n \pi}{4} - \frac{\phi}{2}, with n = odd integer. Now plug this back into the original equation for R and I get
R_{max} = \frac{ 4V^2 \tan{\phi} }{g} \cos{ 2\phi}
I think I'm approaching this problem wrong. Can anyone give me a simpler way?
sabinscabin said:
if you look at the last post in the thread you gave me, I already got that result. It's just that the R_max I get does not match the R max that's given in the initial problem.
Ops my bad.
First, n must be 1; if it's 3 or higher, than n*pi/4 - Φ/2 would be greater than 90 degrees, and that's impossible given the geometry of the situation. So we know that the optimum angle is pi/4-Φ/2. Substituting it into the equation for R gives:
R=sin(pi/4-Φ/2)cos(pi/4+Φ/2)/cos^2 (Φ)
I've ignored the constants. Since cos(a)=sin(pi/2-a):
R=sin(pi/4-Φ/2)sin(pi/4-Φ/2)
cos(2a)=1-2sin^2 (a), so
R=(1-cos(pi/2-Φ))/2
=(1-sin(Φ))/2
You seem to have decent math skills, so getting from here to the answer should be easy.
you have got \theta = \pi/4 - \varphi/2
so 2sin\theta cos(\theta + \varphi) = 2sin(\pi/4 - \varphi/2) sin(\pi/4 - \varphi/2) =
2sin2(\pi/4 - \varphi/2) = [cos(\varphi/2) - sin(\varphi/2)]2
[cos(\varphi/2) - sin(\varphi/2)]2/cos2\varphi
= {[cos(\varphi/2) - sin(\varphi/2)]/cos\varphi}2
= {[cos(\varphi/2) - sin(\varphi/2)]/[cos2(\varphi/2) - sin2(\varphi/2)]}2
= {1/[cos(\varphi/2) + sin(\varphi/2)]}2
= 1/(1 + sin\varphi)
  • · Replies 21 ·
