Proof: a/b + b/a is Int iff a=b
  • Thread starter Thread starter DrAlexMV
    Proof
The discussion revolves around proving that the expression a/b + b/a equals an integer if and only if a equals b, where a and b are nonzero positive integers. The participants explore concepts related to divisibility and the implications of the greatest common divisor (gcd) in their reasoning.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the implications of assuming a and b are relatively prime and how that affects the proof. There are attempts to derive contradictions based on the properties of divisibility and prime factors.
The conversation is active, with participants questioning the validity of the original proof and exploring alternative reasoning. Some guidance has been offered regarding the gcd and its implications, but there is no explicit consensus on the proof's validity yet.
Participants note that the original proof may fail if a and b share common factors, and they are considering how to address this in their reasoning. The discussion includes considerations of specific cases, such as when a and b are prime or relatively prime.
DrAlexMV
Prove: a/b + b/a equals an integer, for any a,b nonzero positive integers, if and only if a = b
Divisibility: d|e implies e = dj where j is an element of j for d and e element of the integers.
1. Let a/b + b/a = k where k is an element of the integers
2. a/b + b/a = (a^2 + b^2) / ab
3. (a^2 + b^2) = kab
4. Let (a^2 + b^2) = c where c is an integer
5. c = kab
6. Step five implies the three following things: a|c , b|c , ab|c
7. If a|c and b|c, then ab does not divide c and therefore step 6 demonstrates a contradiction.
8. Therefore a must equal b
Is this a solid proof? If not, could you tell me where the weakness is?
EDIT : If a and b are relatively prime. I cannot use my contradiction then! Any ideas ?
Thank you for your time.
One thing that positive integer could be odd or even.
Eh what if a and b are relatively prime. I cannot use my contradiction then! Any ideas ?
mtayab1994, what do you mean with that?
sorry my earlier comment was a typo i wanted to say if they were prime like you just stated
Yeah, I thought about that after I typed it. Any idea on how to solve this?
Well it seems that it really doesn't matter if they're prime, because take for example 5 ( a prime number). In this case we get c=a^2+b^2=50 so c/a=10 and c/b=10 and c/ab=2; and this will work for any number and that number c divided by ab is the same as a/b+b/a. Hopefully you can something in this.
I don't understand the contradiction. If a and b divide c ab can definitely divide c as well. In fact I don't see anything about a=b until after you got a contradiction already.
At step 3 just consider the equation mod a and b
Yes that's what i tried showing him in the previous reply.
I'm a little vague on what you think the contradiction is. I would assume a and b are relatively prime to begin with. (Otherwise you could just remove the common factors). Now suppose p is a prime divisor of a. What could you conclude from (a^2 + b^2) = kab?
Relatively prime does not mean that they are prime. Relatively prime means that the gcd(a,b) = 1. They have no common factors. My contradiction fails if a and b have no common factors.
Office Shredder, if a|c and b|c, then ab|c if gcd(a,b) = 1. Otherwise it does not work.
Would that mean that p|(a^2 + b^2) ?
Yes.
Where does that take me?
If there are multiple people responding it's a good idea to hit the Quote button before you reply to make it clear who you are responding to. But yes, assume gcd(a,b)=1 and try to derive a contradiction with that.
I'm not so sure.
So,
1. a^2 + b^2 = kab
2. Let gcd(a,b) = 1
3. Let p be a prime divisor of a
4. Then p|a^2 + b^2
I'm thinking but it is not clicking.
DrAlexMV said:
So,
1. a^2 + b^2 = kab
2. Let gcd(a,b) = 1
4. Then p|a^2 + b^2
Can't you show p must divide b as well?
Would this work?
a^2 + b^2 = pj where j is an element of the integers
a = pw where w is an element of the integers
Then:
p^2w^2 + b^2 = pj
we reorganize to:
b^2 = p(j - pw^2)
we let j - pw^2 = v where v is an element of the integers
so b^2 = pv
that implies p|b^2 and b times b will not create a factor p since p is prime therefore,
p|b
DrAlexMV said:
Would this work?
Then:
p^2w^2 + b^2 = pj
we reorganize to:
b^2 = p(j - pw^2)
so b^2 = pv
p|b
That's a little more complicated than it needs to be but if p|a then p|a^2 and p|kab, so p|b^2. And if p is prime, then sure, p|b. Doesn't that contradict gcd(a,b)=1?
Yes, I saw that whenever you told me to prove that p|b. Thank you a lot, this proof really made me think for some reason.
