Proving (n+1)^4 < 4n^4 for n >= 3
  • Thread starter Thread starter kmeado07
    Induction Proof
To prove that (n+1)^4 < 4n^4 for n >= 3, the method of mathematical induction is suggested. The base case for n=3 should be verified first. Assuming the inequality holds for n, the next step is to show it holds for n+1, transforming the expression into (n+2)^4 < 4(n+1)^4. The discussion emphasizes that since the question requires a strict inequality, additional positive terms can be added to the left side without violating the inequality. The importance of ensuring that any subtracted terms are positive is also highlighted to maintain the validity of the inequality.
kmeado07
Show that (n+1)^4 < 4n^4 whenever n >= 3
I need to prove this by induction, so i assume it is true and then prove that when n=n+1 it is also true.
so it would become (n+2)^4 < 4(n+1)^4
Im not sure how to continue this though.
The first step is to check it for n = 3. Then assume it is true for n. I haven't tried this, but I would start by something like:
((n + 1) + 1)^4 = (n + 1)^4 + 4 (n + 1)^3 + ...
Then use the induction hypothesis.
Note that, because your question is "show that ... is STRICTLY SMALLER than ... " you can always throw away terms you know are positive. For example, for n >= 3, if you have that (n + 1)^4 < 4 n^4 then you also have that (n + 1)^4 + 14n + 3 < 4 n^4, because you are only adding terms which make the left hand side bigger so the inequality will keep holding. Watch out however, that the terms have to be positive, if (n + 1)^4 < 4 n^4 then it needn't be true that (n + 1)^4 - 20 < 4 n^4.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
