Proof f(x)>g(x) in an interval
  • Thread starter Thread starter Dank2
    Interval Proof
30 replies · 5K views
Dank2
let fx, gx be continuous in [a,b] and differentiable in (a,b). at the end of the interval f(a) >= g(a).
and f'(x) >g'(x) for a<x<b.
proof f(x) > g(x) for a<x<=b
Attempt:
There is a statement says that if the f'x = g'x for x in [a,b] , then there exists k such that f'x - g'x = k for any x in [a,b]
but f'(x) = g'(x) + t(x), where t(x) isn't have to be a line. and i cannot use the statement
Dank2 said:
and f'(x) > g'(x) for a<x<b.
Shouldn't that be a < sign ?
Might be hard to prove, then:
a=0, b =2, f(x) = x, g(x) = 1 satisifies all criteria, yet f < g on half the interval.
[edit] Ah, the end of the interval is at the beginning. My bad o:) :rolleyes:
but f(a) is not equal or or bigger thatn g(a).
Yeeah, I get it. Was wrongfooted by the 'end' term.
With f' - g' > 0 and the definition of derivative you should be able to go through the interval without f-g diminishing from its starting value f(a)-g(a).
f'(x) - g'(x) = lim(f(x+h) -f(x) -g(x+h) -g(x))/h > 0
like that? how can i take out f(x) - g(x)
Ergo there is a h> 0 such that f(a+h)-g(a+h) > f(a)-g(h)
wait but we need x no?, a is the start of the interval
So a+h is the new 'beginning' for the next step. Crux is if we can prove this can be continued all through the a,b interval in a finite number of steps.
but why doesn't the limit and the h at the denominator making problems here?
what I've got is
lim (f(x+h) - g(x+h))/h > lim (f(x) + g(x))/h
what I've got is
ok i think i got it, the limit doesn't change it much
what I've got is
I'm not sure looking at the definition of the derivative is the best way forward. In any case, it's best to introduce a new function, let's call it ##k## such that:
##k(x) = f(x) - g(x)##
What can you say about ##k##? And what theorems do you know?
it is continuous and it is differentiable.
However there is a theorem i know regarding k(x) being constant, but i cannot assume it here.
Do you know the Mean Value Theorem?
So;
(f(b) - f(a))/b-a > (g(b)-g(a))/b-a
and i can pick any b-a such that the diffrence is very small, so i can use x instead of it ?? so f(b) - f(a) = f(b)
Dank2 said:
So;
You need to switch your attention to ##k(x)##. Also, I suggest a proof by contradiction using the MVT.
ok K'(x) >0 for any x in the interval.
That's true. What are you trying to prove about ##k(x)##?
Thread moved from Precalc section. @Dank2, please post questions involving differentiation (and differentiable functions) in the Calculus & Beyond section.
that is always positive
You need to put a bit more effort in here! You're doing real analysis, which requires precision in terms of the statement of a problem. I'll help you on this point, but you need to start thinking more (pure) mathematically:
We have that ##k## is continuous on ##[a, b]##, differentiable on ##(a, b)##, ##k(a) \ge 0## and ##\forall x \in (a, b), \ k'(x) > 0##.
We must show that ##\forall x \in (a, b], \ k(x) > 0##
same problem as before
assume k(x) <0 for some x latter than a, then we will get at one point k'(x) = 0, since at the start of the iterval k(x) > 0 , and it is a continuous function. and that's a contradiction since k'(x) >0 for any x in the interval, and ther fore there is no point where k(x) < 0
This answer shows that you are lacking mathematical technique. In this case, you need to reserve ##x## as your variable and use, for example, ##x_0, x_1, x_2## for specific values of ##x##.
Also, I think you are confusing the Mean Value Theorem with the Intermediate value theorem. Note that we cannot assume that ##k'(x)## is a continuous function, so applying the IVT to ##k'(x)## is not possible. So, you will need to apply the MVT to ##k(x)##.
i just get
k'(c) = k(b) - k(a) = f(b)-g(b) - (f(a) - g(a)) (with b-a at the denominator)
or do i not use it right?
Dank2 said:
i just get
The MVT applies to any interval. In this case it won't be ##[a, b]##. If you find an ##x_0## such that ##k(x_0) \le 0##, then you can apply the MVT to ##[a, x_0]##.
can't see how to get the contradiction, ill work on it next time, thanks friend.
