Proof: Infinitely Many Rational Square Roots of Natural Numbers
  • Thread starter Thread starter kaos
    Proof
The discussion confirms that there are infinitely many natural numbers \( n \) for which the square root is rational, as demonstrated by the proof that \( n = x^2 \) where \( x \) is any natural number. The argument is valid, provided one establishes that different natural numbers yield different squares, preventing any "collapse" into a finite set of values. The proof relies on the principle that if there were a maximum rational square root, one could always find a larger natural number with a rational square root, thus ruling out the finite case.
  • Understanding of natural numbers and their properties
  • Basic knowledge of square roots and rational numbers
  • Familiarity with proof techniques, particularly proof by contradiction
  • Concept of unique squares of natural numbers
  • Study the properties of natural numbers and their squares
  • Learn about proof by contradiction and its applications in mathematics
  • Explore the concept of rational numbers and their relationship with square roots
  • Investigate the implications of unique mappings in mathematical proofs
Mathematicians, educators, students in number theory, and anyone interested in the properties of natural numbers and rationality in mathematics.
kaos
Is this a valid proof? Also is this way of doing it valid?
Statement : There are infinitely many natural numbers n where the square root of n is rational.
Proof:
sqrt of n = x (where x is natural)
n= x squared
And n can be any natural number(x) squared ,and there are infinitely many natural numbers (x)
therefore there are infinitely many n which has a natural square root. Since natural numbers are rational , there are infinitely many natural numbers n where the square root of n is rational.
Proof:
n= x squared
Your argument seems fine. There is one small point, though, that you should consider: how do you know that different integers x yield different integers x^2? (You need to argue that in order to know that squaring does not cause everything to collapse into a small, finite set of values.)
Try going like this...
There are two possibilities:
1.There are infinitely many natural numbers n where the square root of n is rational.
2.There are finite natural number whose roots are rational.
If things were go as 1. then the proof is complete. If things were to go as 2. then we have to prove it wrong..
If second condition is satisfied then we will come up with a maximum number nmax (say) whose root is rational. Prove that there exist another number greater than nmax whose root is rational.
So the 2. possibility is ruled out, hence we are left with only one possibility which is 1.
Regards
Thanks for responding.
Isn't the square of an integer always different?(except 1 or 0 i guess)?
And I don't understand the "(You need to argue that in order to know that squaring does not cause everything to collapse into a small, finite set of values.)" part (specifically what are you referring to that is collapsing?).
Regards
Yes i know of proof by contradiction, but i used a more straightforward method. Though I am not entirely sure my proof works.
It's perfectly valid. The set of all n^2 for n any natural number i.e. {1^2,2^2,3^2,...} has an infinite number (since there are no duplicates, that's what Ray was saying about 'collapsing') of elements all of which are all natural numbers. Their square roots are all natural numbers, i.e. {1,2,3...} hence rational. That's what you are saying, right? In fact, those are the ONLY natural numbers that have rational square roots, but you don't need to show that.
No, that is not true. (2)^2= (-2)^2. However, YOU are working with natural numbers, not integers (do you understand the difference?) so it is true. But the point is that, unless you are "given" that, you need to prove it. Suppose m and n are different natural numbers. Then n- m\ne 0 because they are different. Further m+n\ne 0 (why?). Therefore m^2- n^2= (m- n)(m+ n) is not 0 so m^2 is not equal to n^2.
For example, when squaring, the set {-3, -2, 2, 3} "collapses" to the smaller set {4, 9}. The proof above shows that cannot happen for the natural numbers.
HallsofIvy said:
No, that is not true. (2)^2= (-2)^2. However, YOU are working with natural numbers, not integers (do you understand the difference?) so it is true. But the point is that, unless you are "given" that, you need to prove it. Suppose m and n are different natural numbers. Then n- m\ne 0 because they are different. Further m+n\ne 0[/tex] (why?). Therefore m^2- n^2= (m- n)(m+ n)[/tex] is not 0 so m^2 is not equal to n^2.<br /> <br /> <br /> For example, when squaring, the set {-3, -2, 2, 3} "collapses" to the smaller set {4, 9}. The proof above shows that cannot happen for the natural numbers.
<br /> <br /> Ah right i confused naturals(whole numbers larger than zero) with integers (integers include less than zero whole number right). Thanks for the explanation.
  • · Replies 24 ·
