Proof of Cauchy Sequence: e/2 Appearing in Proof
  • Context: Graduate
  • Thread starter Thread starter lion0001
    Cauchy Sequence
The discussion revolves around the proof that every convergent sequence is a Cauchy sequence, specifically focusing on the appearance and justification of the term e/2 in the proof. Participants explore the implications of choosing e/2 and its role in demonstrating the Cauchy property of sequences.
  • One participant asserts that every convergent sequence is a Cauchy sequence and provides a proof involving the choice of e/2.
  • Another participant questions the necessity of the e/2 choice, suggesting that the proof could proceed without referencing the derivation of 2e.
  • Some participants discuss the logic behind using e/2, noting that it simplifies the proof by ensuring that the sum of two terms remains within the bounds needed to demonstrate the Cauchy property.
  • There is mention of Universal Elimination as a logical principle that supports the use of e/2 in the proof.
  • Several participants express confusion about the transition from discussing the interval of length 2e to using e/2, with some seeking clarification on the arithmetic involved.
  • One participant highlights the difference between "suppose" and "choose" in the context of mathematical proofs, emphasizing the implications of these terms in analysis.
Participants do not reach a consensus on the necessity of the initial derivation of 2e in the proof. Some believe it is essential for clarity, while others argue that the proof can stand without it. The discussion remains unresolved regarding the best approach to presenting the proof.
Participants express varying levels of understanding regarding the logical structure of the proof and the implications of different choices of ε. There is also a recognition of the potential for ambiguity in the presentation of mathematical arguments in textbooks.
This discussion may be useful for students studying real analysis, particularly those grappling with the concepts of convergence and Cauchy sequences, as well as the logical foundations of mathematical proofs.
lion0001
Every convergent sequence is a cauchy sequence
Proof: Suppose {a_n} converges to A, choose e > 0 , then e/2 > 0
there is a positive integer N such that n>=N implies abs[a_n - A ] < e/2
the difference between a_n , a_m was less than twice the original choice of e
Now if m , n >= N , then abs[a_n - A ] < e/2 and abs[a_m - A] < e/2 , hence
abs[a_n - a_m ] = abs[ a_n - A + A - a_m ] <= abs[a_n - A ] + abs[ A - a_m ]
= abs[a_n - A ] + abs[ a_m - A ] < e/2 + e/2 = e
thus {a_n} is cauchy
the part where i have trouble understanding this proof is , where does the e/2 comes from?
in other words how does e/2 appears in the proof,
if the answer is this " the difference between a_n , a_m was less than twice the original choice of e " i would like to see the arithmetic that produces e/2
Now if m , n >= N , then abs[a_n - A ] < e' and abs[a_m - A] < e'
Since {a_n} is convergent, you know that the above statement is true for all e', therefore it is certainly true when e' = e/2. It is just a convenient choice for e' since at the end when you add the two e/2's together you get e, which is what you needed.
thank you very much, i thought this was derived in a more complicated wayANY OTHER ANSWERS ARE WELCOME
The law of logic that allow MATTICUS to do what he did is called Universal Elimination.
Since the sequence converges ,then for all Ε>o there exists an N...e.t.c,e.t.c.
But ε/2,ε/3, ε/4 ,ε/5 ......ε/n are all E"s >0, and according to the above law ,we can have for ε/2>0, an N such ...e.t.c,e.t.c.
If all people in a village are poor then Tom ,who stays in the village is poor
Note the ε>0 DENOTES a positive quantity ,hence any quantity which is positive could apply.
For example ε^4 +4 ,could apply since ε^4 + 4 is bigger than 0.
ε^2 + 2ε + 3 ,is applicable as well
This is what it is in my book, i don't know how it went from saying that the difference is 2e and then using e/2 . The part that confuses me , is why the book outlines (1) to then use it in the proof, it looks that (1) doesn't even matter because since e > 0 then e/2 will do just fine.
(1) Suppose { a_n } converges to A. Choose e > 0, THere is a positive integer N such that, if
n, m >= N , then A - e < a_n < A + e and A - e < a_m < A + e
Thus for all n, m >= N we find a_n ∈ ( A - e , A + e ) and
a_m ∈ ( A - e , A +e ) . the set ( A - e, A +e ) is an interval of length 2e ,
hence the difference between a_n, and a_m is less then 2e
we will now state a theorem , the proof of which we have just outlined
THEOREM :Every convergent sequence is a cauchy sequence
by (1) the difference between a_n , a_m was less than twice the original choice of e
What is the name of your book?
You must realize that many analysis books ,apart from the terrible mistakes they have,
are written in "a bent minded" manner
the name of the book is , Introduction to Analysis , by Edward D. Gaughan 5th edition
ISBN 0534351778
i have a question , can we just forget about part (1) where the author gets 2e , and just go straight to the proof, because the proof seems that doesn't need the part where the author gets 2e
Well, I'm taking Analysis now, and that's exactly how you show convergence implies Cauchy--that is, without appealing to (1).
The definition for limit of a sequence {Sn} says for all e there exists a N such that n>N implies |Sn-n| < e. It doesn't say |Sn-n| < 2e. To use 2e you would have to prove that if there is an M such that m > M implies |Sm - m| < 2e then there must also be an N such that n>N implies |Sn-n| < e.
He mentions it because as he says, it is an outline of his proof. Note that in the outline, when he picks the number e, it guarantees |an - am| < 2e. He's trying to explain how he came up with the seemingly random substitution. If using e resulted in 2e, then using e/2 would result in e, which implies the sequence is Cauchy.
So yes he could have left it out, but he probably thought it was beneficial for the reader to see how he miraculously got the e/2.
In analysis ,there is a great difference between suppose or given and choose
Choose stands for there exists . So you can say choose an N or k belonging to natural Nos
or a δ>0 in the limits of a function ,and you can say given or suppose ε>0.
When you say given ε>0 ,you start a hypothesis,which in conjunction with the definition of a limit and the law of logic called M.Ponens will enable to choose an N or k.
The following is a more detailed proof of the above theorem:
Suppose ε>0,then ε/2>0.
Now since [tex]a_{n}[/tex] converges to A,for all θ>0 there exists an N belonging to natu ral Nos such that
......l[tex]a_{k}[/tex]-Al <θ...for all k, k>=N.
Now using then Universal Elimination law put θ=ε/2,and we have:
If ε/2>0 then there exists an N belonging to natural Nos such that:
....for all k, k>=N then l[tex]a_{k}[/tex]-Al<e/2.....
But since ε/2>0 by the law of M.Ponens indeed we have that there exists an N belonging to natural Nos such that:
.....for all k, k>=N then l[tex]a_{k}[/tex]-Al<e/2......
Now suppose ,n>=N AND m>=N.
Since now for all,k k>=N then l[tex]a_{n}[/tex]-Al<e/2...
if again by using the law Universal Elimination we put k=n firstly and then k=m we have:
if n>=N THEN l[tex]a_{n}[/tex]-Al<e/2 and
if m>=N THEN l[tex]a_{m}[/tex]-Al<e/2
And using now the supposition ,n>=N AND m>=N,the above and M.Ponens we conclude:
l[tex]a_{n}[/tex]-Al<e/2 and l[tex]a_{m}[/tex]-Al<e/2
...and....
l[tex]a_{n}[/tex]-[tex]a_{m}[/tex]l <ε by using the above and the triangular inequality
