Proof of Multivariable chain rule
The multivariable chain rule is expressed as \(\frac{\mbox{d}z}{\mbox{d}t}=\frac{\partial z}{\partial y}\frac{\mbox{d}y}{\mbox{d}t}+\frac{\partial z}{\partial x}\frac{\mbox{d}x}{\mbox{d}t}\) where \(z=z(x(t),y(t))\). A rigorous proof is not necessary for understanding, but an intuitive approach involves considering the change in \(f\) as a sum of changes along each variable direction. The continuity of second derivatives is essential for the equality \(\frac{{\partial}^{2}z}{\partial x \partial y}=\frac{{\partial}^{2}z}{\partial y \partial x}\) to hold, which is confirmed by the MIT OCW multivariable calculus resources.
  • Understanding of multivariable calculus concepts
  • Familiarity with partial derivatives
  • Knowledge of the chain rule in single-variable calculus
  • Basic comprehension of continuity in functions
  • Watch the MIT OCW video on multivariable calculus, specifically Lecture 12 on gradients
  • Study the proofs of the multivariable chain rule in advanced calculus textbooks
  • Explore the implications of continuity on the existence of partial derivatives
  • Practice problems involving the application of the multivariable chain rule
Students and professionals in mathematics, particularly those studying calculus, as well as educators seeking to explain the multivariable chain rule and its applications.
dimension10
I was wondering how to prove the multivariable chain rule
where z=z(x(t),y(t))
I don't really need an extremely rigorous proof, but a slightly intuitive proof would do.
Also how does one prove that if z is continuous, then
Thanks in advance.
As for your second question, one doesn't- what you have written is not true. If z is only continuous, the partial derivative, much less the second derivatives, may not even exist. What you need is that the second derivatives are continuous.
The MIT OCW videos on multivariable calculus have video which covers this: http://ocw.mit.edu/courses/mathemat...fall-2007/video-lectures/lecture-12-gradient/
To summarize the argument (though I doubt this is particularly rigorous)
<br /> df = \frac{\partial f}{\partial x} dx + \frac{\partial f}{\partial y} dy + \frac{\partial f}{\partial z} dz<br />
Then, if we assume that f, x, y and z are all functions of t we divide by dt
<br /> \frac{df}{dt} = \frac{\partial f}{\partial x} \frac{dx}{dt} + \frac{\partial f}{\partial y} \frac{dy}{dt} + \frac{\partial f}{\partial z} \frac{dz}{dt}<br />
Again this is not rigorous, if you want an idea of why this could be true think of the way a vector is composed by summing orthogonal parts; take the amount f will change when you move an amount along the x direction, multiplied by the amount x will move when you change t a certain amount, then repeat this for y and z and sum for the final change in f.
Same proof as the single variable chain rule.
Makes sense. thanks.
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 17 ·
