Proof of S^n=0 When S is Lower Triangular Matrix
  • Thread starter Thread starter Nusc
    Matrix
10 replies · 3K views · last reply
Nusc
If S is a lower triangular matrix (n by n), S^n is the zero matrix.
S =
0 0 0 0 ... 0
1 0 0 0 ... 0
0 1 0 0 ... 0
0 0 1 0 ... 0
0 0 0 0 .1.0
S^2 =
0 0 0 0 ... 0
0 0 0 0 ... 0
1 0 0 0 ... 0
0 1 0 0 ... 0
0 0 0 0 1.. 0
How do I show this using induction?
No. So given S as I defined above then computing S^2, and S^3 so forth, the entries lower each row for each n. how do I generalize this?
Use the definition of matrix multiplication to show that the value of Sk-1k,1 = 1 but Sk-1< k,* = 0 and Sk-1k, >1and<n = 0 => Sk*,* = 0.
Where * means any row and any column.
edit: If you are trying to prove that statement in general, you might want to consider the identity matrix which is both n x n and lower triangular.
First, a lower triangular matrix is one where the entries above the diagonal are zero. The matrix you show has ones down the lower subdiagonal and zeroes everywhere else.
Second, the statement isn't true.
Here's a counterexample for n = 3.
S =
[1 0 0]
[1 1 0]
[1 1 1]
S^2=
[1 0 0]
[2 1 0]
[3 2 1]
S^3=
[1 0 0]
[3 1 0]
[6 3 1]
The upshot is that S is a lower triangular 3 x 3 matrix, but S^3 != 0.
Are you sure the question isn't in regards to a 'strictly lower triangular matrix'?
The matrix is this:
S =
0 0 0 0 ... 0
1 0 0 0 ... 0
0 1 0 0 ... 0
0 0 1 0 ... 0
0 0 0 0 .1.0
it's not a lower triangular matrix.
It would be helpful if we knew exactly how the problem is stated. In your first post, here is what you had:
The somewhat sparse n x n matrix with 1s on the subdiagonal appeared in your attempt at a solution.
Is the problem statement to show that for that matrix S, S^n = 0?
Inquiring minds would like to know...
Okay.
Given
0 0 0 0 ... 0
1 0 0 0 ... 0
0 1 0 0 ... 0
0 0 1 0 ... 0
0 0 0 0 .1.0
Compute (S^n)(S^n*) and (S^*n)(S^n)
where * is the complex conjugate transpose.
Nusc said:
The matrix is this:
S =
0 0 0 0 ... 0
1 0 0 0 ... 0
0 1 0 0 ... 0
0 0 1 0 ... 0
0 0 0 0 .1.0
Actually, that is a "lower triangular matrix" (it has only 0s above the main diagonal), just not a general lower triangular matrix as was intially implied.
So in Compute (S^n)(S^n*) and (S^*n)(S^n)
they're both zero correct?
