MHB Proof of the strong maximum principle
mathmari
MHB
Hey! :o
I am looking at the proof of the strong maximum principle:
If a function $u$ satisfies the Laplace's equation at the open space $D$ and is continuous at the boundary $\partial{D}$ and achieves its maximum at $\partial{D}$ and at a point of $D$ then the function is a constant.
which is the following:
$x_M$ : the point where the function achieves its maximum
$x_M \in D$
$u(x) \leq u(x_M)=M, \forall x \in D$
$u(x)=u(x_M), \forall \text{ choice of circle }$
(Thinking)
I am facing some difficulties understanding this proof.. (Worried)
So, we take a circle with center $x_M$.
Then from the mean value property we have that:
$$u(x_M)=\frac{1}{2 \pi a} \int_{| \overrightarrow{r'}|=a}{u(\overrightarrow{r'})}ds$$
We consider that $x_M \in D$ is the point at which $u$ achieves its maximum, so
$$u(x) \leq u(x_M)=M, \ \ \ \forall x \in D$$
So, we have the following:
$$M=u(x_M)=\frac{1}{2 \pi a} \int_{| \overrightarrow{r'}|=a}{u(\overrightarrow{r'})}ds$$
But since the integral is at the boundary $\partial{D}$, and we have supposed that $M$ is the maximum of all points at $D$, we cannot say that
$$M=u(x_M)=\frac{1}{2 \pi a} \int_{| \overrightarrow{r'}|=a}{u(\overrightarrow{r'})}ds \leq \frac{1}{2 \pi a} \int_{| \overrightarrow{r'}|=a}{M}ds$$
right??
How can I continue then to show that the function is constant?? (Wondering)
Hey! (Mmm)
right??
Sure you can, but it doesn't help you. (Wasntme)
Do something with Laplace's equation? (Thinking)
I thought I could it as followed:
$$M=u(x_M)=\frac{1}{2 \pi a} \int_{| \overrightarrow{r'}|=a}{u(\overrightarrow{r'})}ds \leq \frac{1}{2 \pi a} \int_{| \overrightarrow{r'}|=a}{M}ds = \frac{M}{2 \pi a} \int_{| \overrightarrow{r'}|=a}ds =M$$
So the symbol $\leq$ should be $=$, so $u=M$.
Is this wrong?? (Wondering)
What could I do?? (Wondering)
It is correct, but you are restating something you already know.
The left hand side is equivalent to the right hand side. (Wasntme)
Well... you could for instance write down Laplace's equation in polar coordinates, separate the variables, add the boundary condition that the function of angle has period $2\pi$... (Wondering)
$$u_{rr}+\frac{1}{r}u_r+\frac{1}{r^2}u_{\theta \theta}=0 ,\ \ \ 0 \leq \theta \leq 2 \pi, \ \ \ 0 \leq r \leq a$$
Applying the method of separation of variables, the solution is of the form $u(r, \theta)=R(r) \Theta(\theta)$
the boundary condition that the function of angle has period $2\pi$:
$u(a,\theta)=h(\theta), h(\theta)=h(2 \pi + \theta)$
The solution is the following:
$$u(r, \theta)=\sum_{n=0}^{\infty} [A_n \cos{(n \theta)}+B_n \sin{(n \theta)}]r^n \Rightarrow \dots \Rightarrow \\ u(r, \theta)=\frac{a^2-r^2}{2 \pi} \int_0^{2 \pi} \frac{h(\phi)}{a^2+r^2-2ar \cos{(\theta-\phi)}}d \phi$$
Do I have to use the last formula?? (Wondering)
Now that you mentioned it, didn't you have a proof (using that formula) that the average of the boundary is equal to u(0)?
Perhaps you can use that. (Thinking)
Yes, when we have a circle with center at $0$.
At the post #1, I took a circle with center at $x_M$, and then the average of the boundary is equal to
Since $u$ achieves its maximum at $\partial{D}$ and at a point of $D$, do we maybe have to suppose that $M$ is the maximum of all points at $D$ and at $\partial{D}$?? (Wondering)
Then it would be as followed:
We take a circle with center $x_M$.
Then from the average of the boundary we have that:
We consider that $x_M \in \overline{D}$ is the point at which $u$ achieves its maximum, so
$$u(x) \leq u(x_M)=M, \ \ \ \forall x \in \overline{D}$$
($\overline{D}=D \cup \partial{D}$)
Can we continue from here?? (Worried)
Or should I use the average of the boundary in an other way?? (Thinking)
Since you can use the proposition that the value at the center is equal to the average at a circular boundary, it follows that all values at any circle around the center must be $M$... (Thinking)
I got stuck right now... (Worried)
Could you explain me further this implication?? (Thinking)
I think it is like this.
Suppose we start with this point $x_M$ and draw a very small circle around it.
Since $x_M$ belongs to the interior of $D$, there must be a radius $r$ such that the circle fall entirely within $D$.
According to the Poisson kernel for the polar Laplace's equation, the value of $u$ at the center is the same as the average value of $u$ on a circle around that center.
Or isn't it? (Thinking)
So the values on our small circle should be sometimes lower than $u(x_M)$ and sometimes higher than $u(x_M)$ in such a way that the differences cancel out on average, giving an average of just $u(x_M)=M$.
However, since $M$ is actually the maximum on $D$, it follows that no value on the circle can be higher than $M$. And since the average has to come out as $M$, no value can be lower than $M$.
Therefore, each value on our small circle must have value $M$.
Or am I wrong? (Thinking)(Thinking)
Yes, it is like that! (Yes)
Ahaa... (Thinking) If there were values that are lower than $M$, would the average be lower than $M$??
Any value lower than $M$ would pull the average down (assuming $u$ is continuous)... (Nod)
Ahaa...Ok! I understand! Thank you very much! (Mmm)
