Proof that lim x->0 log(1+x)/x = 1
  • Level: Graduate
  • Thread starter uman
    Proof
12 replies · 39K views · last reply
uman
Given that [tex]\log{(1+x)}=\int_0^x\frac{dt}{1+t}[/tex], how would one prove that [tex]\lim_{x \to 0}\frac{\log{(1+x)}}{x}=1[/tex]?
Just use l'Hôpital's rule and the fundamental theorem of calculus.
Thanks! I had thought of that. However, L'Hôpital's rule is introduced much later in this book so I assume I'm not supposed to use it. It's so far covered logarithms, differentiation and integration techniques... any other ideas?
Ok, if you can't use l'Hôpital, how about this? Subtract a log(1) from the numerator in the expression of the limit. It should look quite familiar now. :-D
Sorry, I should have mentioned something: You're supposed to prove it using the identity I gave in the first part of my post. This is part B of an exercise in apostol. Part A was to prove it using your method, which I did.
The statement of part A was something like "Prove the relationship using the definition of f'(1), where f(x) = log(x)" or something of that nature.
Express [itex]1/(1+t)[/itex] as an infinite series, integrate from 0 to x, divide by x, and take the limit as [itex]x\to 0[/itex].
Meh. The book hasn't covered series' either. Oh well.
I haven't tried this yet, normally I would go with either of Monchot's suggestions, but you could try expressing the integral in terms of Riemann sums. I think that should work.
For the expression
[tex]I=\frac{1}{x}\,\int_0^x\frac{d\,t}{1+t}[/tex]
apply the change of variables [itex]t=x\,u,d\,t=x\,du[/itex], so
[tex]I=\int_0^1\frac{d\,u}{1+x\,u}[/tex]
Then
[tex]\lim_{x \rightarrow 0}I=\int_0^1 \lim_{x \rightarrow 0}\left(\frac{1}{1+x\,u}\right)\,d\,u=\int_0^1 d\,u=1[/tex].
You are allowed to change order between the integral and the limit, since the integral exists by hypothesis.
Rainbow Child's suggestion crushes mine :( But I just tried it, and it works as well =]
Thank you Rainbow Child! I understand your proof and it makes perfect sense. Very clever!
Lim x->0 (x(1+(x/2)+((x^2)/3)+....))/x
=lim x->0 (1+(x/2)+((x^2)/3)+....)
=1+0+0+0......=1
As lovely as it is, Rainbow Child's suggestion requires knowing that, in this case,
[tex]\lim_{x\to 0} \int_0^1 \frac{dt}{1+ xt}= \int_0^1 \lim_{x\to 0}\frac{dt}{1+ xt}[/tex]
which, while true, probably requires deeper math than uman, who has not yet dealt with L'Hopital's rule or power series, has available.
