Proofing Euler's Phi Function.
  • Thread starter Thread starter xWhiteyx
    Function Phi
The discussion centers on proving the expression for Euler's Phi function, specifically ϕ(p²) in terms of a prime number p. It is established that ϕ(p) equals p-1, leading to the conclusion that ϕ(p²) equals p(p-1). The challenge lies in providing a proof for this expression, which involves understanding that numbers less than p² that are not relatively prime to p² must be divisible by p. Participants express curiosity about extending this reasoning to higher powers, such as p³, confirming that the same logic applies. The conversation emphasizes the need for a clear proof using the definition of the Phi function.
xWhiteyx
Generally, I am stumped by the Phi function. I have found out the pattern but I am having difficulty proving it.
i) When p is a prime number, obtain an expression in terms of p for:-
ϕ(p²)
ϕ(p)=p-1
ϕ(p)=p-1
so ϕ(5)=4 therefore p²=5²=25 therefore ϕ(p²)=20
Also, if p=3 then ϕ(3)=2 therefore ϕ(9)=6
It appears that ϕ(p²)= p(p-1)
My problem is that I am not able to proof it. Yes, the pattern is p(p-1) but I am stuck as to how to explain it. Any soloutions?
Just use the definition of phi. phi(p^2) is the number of integers less than p^2 that are relatively prime to p^2. If a number is NOT relatively prime to p^2 then it must be divisible by p. How many numbers less than p^2 are divisible by p?
But how would you then mvoe onto p^3? Would p^3 then be p(p(p-1) or am I wrong. If I take what you say which is that If a number is NOT relatively prime to p^2 then it must be divisible by p Then can I apply the same rule to p^3?
Yes. You can apply the same rule to p^3 if p is prime.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
