Propagation of error: exponents
The discussion centers on understanding the propagation of error in mathematical expressions, particularly focusing on the differences between handling uncertainties in products versus powers. It highlights that the standard quadrature method for combining uncertainties applies only when the uncertainties are independent. For example, measuring two sides of a rectangle allows for independent uncertainties, justifying the quadrature method. However, when calculating the area of a square from a single side measurement, the uncertainties are not independent, making the quadrature method inappropriate. The conversation also mentions the value of John R. Taylor's book, "An Introduction to Error Analysis," as a helpful resource for learning about experimental uncertainty and statistics. Additionally, there is a suggestion to explore a statistics subforum for further questions on this topic.
AndrewBworth
Hi all. I have been trying to understand propagation of error of exponents. Most an. Chem textbooks I see say y = a^x, sy/y = (sa/a)*x. But say y = a*b, then sy/y = ((sa/a)^2 + (sb/b)^2)^.5 . if a = b then sy/y= (2*(sa/a)^2)^.5 = 2^.5*abs(sa/a). This shows the rule y=a^x, sy/y= x^.5*abs(sa/a).
Chemistry news on Phys.org
I think I understand your question. You are asking why the standard way of representing uncertainty in a product (the so-called quadrature method of addition) does not apply to powers.
The most straightforward way to explain this that I've seen may satisfy you. Recall that the quadrature method only applies to uncertainties that are independent of each other. Take a simple example of measuring two sides of a rectangle - the uncertainty in your first measurement is independent of the uncertainty of the second measurement. It is therefore preferable to state the uncertainty in the area of the rectangle using the quadrature method.
Contrast this with measuring only one side of a square and calculating its area. In this circumstance the calculation involves multiplying the same value together and the uncertainties are clearly no longer independent; the quadrature method is not justifiable in this circumstance.
Thank you! I guess I have a thing or two to learn about statistics.
You're welcome. One book that I found extremely useful for the basics of dealing with experimental uncertainty is John R. Taylor's An Introduction to Error Analysis. I would definitely recommend checking it out. I ended up buying a copy.
We also have a statistics subforum for this kind of questions.
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
