Property of thermometric substance
  • Thread starter Thread starter songoku
    Property
The discussion revolves around the properties required for a thermometric substance used in thermometers. Participants are evaluating various characteristics that such a substance should possess to function effectively across a specified temperature range.
  • Participants are examining the validity of different properties listed for thermometric substances, such as linearity of temperature response and the challenges associated with constant expansivity. There is also a consideration of non-liquid thermometric methods.
The conversation is exploring the reasoning behind the selection of specific properties, with some participants questioning their initial assumptions and interpretations. There is an ongoing evaluation of the correctness of reasons provided for dismissing certain options.
Participants are grappling with the implications of properties that vary with temperature, including linear versus non-linear relationships, and the practical challenges of finding a suitable thermometric substance.
songoku
For the construction of a thermometer, one of the essential requirements is a thermometric substance which
a. remains liquid over the entire range of temperature to be measured
b. has a property that varies linearly with temperature
c. has a property that varies with temperature
d. obey Boyle's Law
e. has a constant expansivity
I think the answer can be (a) and (b). The substance must remains liquid so that it can measure the temperature and it must varies linearly with temperature to obtain good measurement. But the answer can be only 1...I don't know how to choose the right one
Thanks
There are thermometers which rely on the expansion / contraction of a piece of metal to measure the temperature: nothing liquid there.
Also, if you have some property which is quadratic in temperature, does that make it impossible to use in a thermometer?
Why do you think c) , d) and e) are not correct?
Hi CompuChip
(c) is wrong because I think it should be linear (which is wrong after I read your post).
(d) is wrong because it's for ideal gas only
(e) is wrong because I think it''s really difficult to obtain a substance that has constant expansivity. The best would be "almost" constant expansivity.
So, I think the answer is (c). But, I don't know whether the reasons for (d) and (e) are correct.
Thanks
Why did you think that was an invalid reason for c?
Varying linearly with temperature is simply a special case of varying with temperature, isn't it?
Hi CompuChip
Yes. I mean that my reason for (c) is wrong. (c) should be the right answer, I think.
And are my reasoning for (d) and (e) correct?
Thanks
