Protecting steel sections from high temperatures
  • Thread starter Thread starter morkeldupreez
    Steel
This discussion focuses on protecting steel structures from temperatures ranging from 650 to 800 degrees Celsius, particularly in the context of a mobile trailer used for transporting solidified materials. The use of insulating ceramic materials is proposed as a potential solution, as they possess low thermal conductivity, which can help maintain a temperature differential. However, the effectiveness of this approach depends on factors such as heat flux and the design of the trailer's beam supports. Suggestions include implementing double-skinned flooring for airflow and using sacrificial tubing to mitigate heat transfer to the steel beams.
  • Understanding of thermal conductivity and heat transfer principles
  • Familiarity with ceramic materials and their insulating properties
  • Knowledge of structural engineering, particularly in relation to steel design
  • Experience with mobile trailer design and material handling
  • Research the properties and applications of insulating ceramics for high-temperature environments
  • Explore structural design improvements for steel beams under thermal stress
  • Investigate the use of double-skinned flooring in high-temperature transport applications
  • Learn about sacrificial materials and their role in thermal management systems
Engineers, materials scientists, and professionals involved in high-temperature applications, particularly those working with steel structures and mobile transport systems.
morkeldupreez
Hi there
How can steel structures be protected from 650 to 800 degree celsius temperatures? Can ceramic material be used to coat the steel sections? Will the ceramic material not keep the heat in and weaken the steel?
Any help will be much appreciated
morkeldupreez said:
Hi there
What is the application of the steel - building structure or furnace housing? The application is key.
An insulating ceramic will have a low thermal conductivity (insulator) and therefore low heat transfer, which will maintain a high temperature differential across the ceramic. With the heat flux (transfer rate) sufficiently low, with steel can conduct away the heat or the heat is convectively transferred to the surrounding air.
If the heat load is high, then an air or water cooling system could be installed between the ceramic and steel.
You really need to give more details of the application (This is not a homework question I hope)
As Astronuc has indicated it depends upon time and heat flux.
Its something I've seen at a mine a while back and it got me thinking.
Its a structure (a mobile trailer) that they put solidified material on that is around the temperature specified earlier.
They usually dump the material directly onto the steel structure, but due to the heat, the steel beams fail quite regularly.
I thought ceramic material could be a solution but wasn't sure, because I do not know that much about it.
The heat flux and stuf like that is unknown.
I know they use the trailer to transport the material about 1000m.
Unknown exactly, but can be estimated sufficiently for our purposes.
From your description, the material placed on the trailer is cooling anyway and does not have a continuous new supply of heat.
I would hazard a guess that refractory linings for the trailer are not used because they are too fragile to survice the dumping process and the jolting from the journey.
I further guess that the beam supports for the trailer are under-designed if they fail often. Simply making them of more massive section should take care of this.
As to the trailer bed you haven't indicated if the hot material is placed directly onto the beams or onto some sort of sheet flooring.
Either way some possibilities suggest themselves.
Firstly any flooring could be double skinned, allowing airflow between the skins. this would prevent excess heat reaching the beam sections.
Alternatively if there is no flooring then flat sacrificial tubing placed (fixed) on top of the beams would serve the same job.
Alternatively the works may simply be in too much of a hurry and allowing the hot material to cool for another couple of minutes may do the trick.
From what I've seen is the current trailer designed in such a way that the hot material is placed directly on top of the steel beams.
They put the hot material on the trailer and it is then transported to an area where it is dumped to be cooled.
The sacrificial tubing is something I did not think of.
Thanks guys
  • · Replies 21 ·
10K
  • · Replies 17 ·
