Prove 2 sqrt(x) > 3 - (1/x) for x > 1
  • Thread starter Thread starter issacnewton
    Calculus 1
The discussion focuses on proving the inequality \(2\sqrt{x} > 3 - \frac{1}{x}\) for \(x > 1\). Participants analyze the function \(f(x) = 2\sqrt{x} + \frac{1}{x}\) and establish that it is increasing on the interval \((1, \infty)\) by demonstrating that its derivative \(f'(x) = \frac{1}{\sqrt{x}} - \frac{1}{x^2} > 0\). The conclusion is reached using the Mean Value Theorem, confirming that \(f(x) > f(1)\) for all \(x > 1\), thereby validating the original inequality.
  • Understanding of calculus, specifically derivatives and increasing functions
  • Familiarity with the Mean Value Theorem
  • Knowledge of inequalities and their properties
  • Basic algebraic manipulation skills
  • Study the Mean Value Theorem in detail to understand its applications
  • Explore the properties of increasing functions and their derivatives
  • Practice proving inequalities using calculus techniques
  • Review the concept of continuity and differentiability in real analysis
Students in calculus, mathematics educators, and anyone interested in understanding the proof of inequalities involving square roots and rational functions.
issacnewton
For ##x> 1##, prove that $$2\sqrt{x} > 3 - \frac 1 x$$
Definition of increasing function
Let ##f(x) = 2\sqrt{x} + \frac 1 x## defined on domain ##[1, \infty)##. Function is increasing if ## f'(x) > 0## on some interval ##I##. This leads to ##\frac{1}{\sqrt{x}} - \frac{1}{x^2} > 0##. So we have ## \frac{1}{\sqrt{x}} > \frac{1}{x^2} ##. Since ## x \in [1, \infty)##, we can flip this ## \sqrt{x} < x^2 ##. Therefore, ##x < x^4##. Hence ##x (x^3-1) > 0##. ##\therefore x(x-1)(x^2+x+1) > 0##. Since ## x > 0 ## and ##(x^2+x+1) > 0## if ## x \in [1, \infty)##, we have ## x > 1##. So ##f(x)## is increasing on ##(1,\infty)##. Its also known that ##f(1) = 3##. How do I proceed from here on ?
Thanks
I would say you are done.
You showed equality for x=3 and that the difference between the two sides is strictly increasing for x>1.
You can use the mean value theorem to make the last step more formal.
Thanks
Your mode of reasoning is unsound. You want to know whether ##f(x)## is increasing on ##(1,\infty)##. So you ultimately want to know if ##\sqrt{x} < x^2## on ##(1,\infty)##. That is true if you can show that ##\sqrt{1} \leq 1^2## and ##(\sqrt{x})' < (x^2)'## on ##(1,\infty)##.
Throughout, you have been essentially assuming what you want to prove and then showing at the end that this implies ##x > 1##. In other words, if A = "##x > 1##" and B = "##f(x)## is increasing", you have shown that ##B \Rightarrow A##, but what what is needed is ##A \Rightarrow B##. Logically there is a real difference.
Huh?
He calculated the derivative and showed that it is positive for x>1 in a direct way (although not with the best possible phrasing). What is unsound about that?
Hello Ray, may be the initial statement of the problem is confusing. But I think I proved that ##f(x)## is increasing on ##(1,\infty)## without any assumptions.
mfb, I don't see how intermediate value theorem would be useful here. To reach eventual conclusion, I have to prove that ##\forall~x \in (1,\infty), f(x) > f(1)##. I tried to assume the negation, ##f(x) \leqslant f(1)##. I reached the contradiction for ##f(x) = f(1)##. I am trying how to get contradiction for ##f(x) < f(1)##. Would this be correct approach ?
It tells you that, for every x0>1 there is a value 1<x<x0 where f'(x)*...=..., and you can use this to show that f(x0)>3.
You have used derivative in the statement. Intermediate value theorem does not talk about any derivatives.
No, you showed that if ##f(x)## is increasing then ##x > 1##. In your case the steps are almost reversible, so doing what you did is harmless, but fundamentally it is a mode of demonstration that you should try to avoid. In your case proving "A implies B" and "B implies A" are essentially reversed arguments of each other, and that is why you can get away with it here. However, logically speaking, "A implies B" and "B implies A" are very different and are sometimes not the same at all: you can have one without the other in some cases.
Sometimes when we solve a problem we essentially do what you did (at least in the exploratory phase); that is, we sometimes start with what we are trying to prove and then work backwards towards the "hypothesis". If we do that it is to gain insight, etc. However, when we write up the final solution we should throw away all those sheets of paper and re-write the argument in the proper fashion. Some instructors would accept what you did, while others would mark it incorrect. Better to be safe.
Ray, ok, I will be careful about my arguments.
I said mean value theorem, not intermediate value theorem.
Ok, I need to prove that ##\forall~x \in (1, \infty), f(x) > f(1)##. We let ## x \in (1, \infty)## be arbitrary. Now consider the interval ##[1, x]##. ##f(x)## is continuous on ##[1,x]## and differentiable on ##(1,x)##. So there is ##c \in (1,x)## such that ## f'(c) = \frac{f(x)-f(1)}{x-1}##. Since ##c >1##, and ##f(x)## is increasing on ##(1,\infty)##, we have ##f'(c) > 0##. Since ##x > 1##, we have ##f(x) >f(1)##. Hence ##2\sqrt{x} + \frac 1 x > 3##, or equivalently, ##2\sqrt{x} > 3 - \frac 1 x##. Since ##x## is arbitrary, this is true for all ##x > 1##. I hope the arguments are correct now.
  • · Replies 105 ·
  • · Replies 40 ·
