Prove Inequality: ||x|^α - |y|^α| ≤ |x-y|^α
  • Thread starter Thread starter IniquiTrance
    Inequality
The forum discussion centers on proving the inequality ||x|^α - |y|^α| ≤ |x-y|^α for all x, y in ℝ and α in (0,1]. Participants explored various approaches, including the triangle inequality and properties of the function f(x) = x^α. Key insights included the use of sub-additivity and the behavior of derivatives of the function, leading to a contradiction method for the proof. The final conclusion confirms that the inequality holds true under the specified conditions.
  • Understanding of real analysis, specifically inequalities and limits.
  • Familiarity with the triangle inequality in metric spaces.
  • Knowledge of the properties of power functions, particularly f(x) = x^α for α in (0,1].
  • Basic concepts of derivatives and their implications in function behavior.
  • Study the triangle inequality and its applications in real analysis.
  • Explore the concept of sub-additivity and its proofs in mathematical contexts.
  • Investigate the properties of power functions and their derivatives for different ranges of α.
  • Learn about contradiction methods in proofs, particularly in the context of inequalities.
Mathematics students, educators, and researchers interested in real analysis, particularly those focusing on inequalities and their proofs.
IniquiTrance
Prove the following inequality holds:
||x|^\alpha - |y|^\alpha | \leq |x-y|^\alpha \qquad (\forall x,y\in \mathbb{R}, \alpha \in (0,1])
I tried squaring both sides, getting:x^{2 \alpha} - 2 (|x||y|)^\alpha + y^{2 \alpha} \leq (x^2 - 2xy + y^2)^\alpha
Any help is much appreciated.
Okay, your first mistake is that you are assuming what you are trying to prove.
I'll start you off and see what you can do from there. This is a two step proof.
Start with |x|^{\alpha} as one case and |y|^{\alpha} as the other. Your goal is to arrive at a conclusion similar to the one you are trying to prove and then combine your answers to get the final answer.
Here's the hint: x = x - y + y and y = y - x + x. See what you can come up with!
Alrighty, thanks for the hint! Please tell me if the following is correct:
By the triangle inequality:
d(y,x+y) \leq d(y, x) + d(x, x+y)
(d(y,x+y))^\alpha \leq (d(y,x) + d(x, x+y) )^\alpha \leq (d(y,x))^\alpha + (d(x, x+y))^\alpha
\therefore (d(y,x+y))^\alpha - (d(x, x+y))^\alpha \leq (d(y,x))^\alpha
Similarly,
(d(x, x+y))^\alpha - (d(y,x+y))^\alpha \leq (d(x,y))^\alpha
Proving that |(d(x, x+y))^\alpha - (d(y,x+y))^\alpha| \leq (d(x,y))^\alpha.
You switched notation up on me, but it looks good. Don't forget to include the part where d(x,y)=d(y,x).
Haha, sorry about that. Thanks for the help!
Hmm, after looking things over again, I realized I'm making an unjustified assumption.
Rewriting my proof in our original notation, slightly differently:
|x-0| \leq |x-y| + |y-0|
|x|^\alpha \leq \left(|x-y| + |y|\right)^\alpha \leq |x-y|^\alpha + |y|^\alpha
|x|^\alpha - |y|^\alpha \leq |x-y|^\alpha
So on the second line, last expression, I have assumed sub-additivity. Namely,
I know how to prove this is true for \alpha = 1/2, 1, but how can I prove it is true for all \alpha\in (0,1]?
Thanks!
Consider f(x) = x^{\alpha}, \quad \alpha \in (0,1], \quad x \in \mathbb{R}^{+}. (this is because in the problem we are considering positive values only, no need for negatives)
What can you tell me about the derivative of f\prime (x)? Something about the derivative that relates x_{1} < x_{2} to x_{1}^{\alpha} < x_{2}^{\alpha}.
Hmm, since f&#039;(x)=\alpha x^{\alpha - 1}, and \alpha - 1 &lt; 0 for \alpha \in (0,1), we have that f ' (x) is decreasing in x. So since x+y>x, and x+y>y by assumption, we have f(x+y)<f(x) and f(x+y)<f(y). But why does this imply f(x+y)<= f(x) + f(y)? Also, why is there no loss of generality by assuming both x,y>0?
Edit: Hmm, what I said above doesn't appear to be right. f '(b) < f '(a) does not necessarily imply f (b)<f(a). I think I've confused myself even further.
f'(x) is actually increasing, just because the exponent is negative doesn't mean the number is negative.
What I am getting at is that since x \geq 0, f(x) = x^{\alpha}, \quad \alpha \in (0,1] is an increasing function. So for a&lt;b, \quad f(a) = a^{\alpha} \leq b^{\alpha} = f(b). I'm sorry if I confused you. If the function was decreasing, a&lt;b would imply \quad f(a) = a^{\alpha} \geq b^{\alpha} = f(b) which is not what we are working towards. Does that makes sense?
Yes, that was rather careless on my part, not your fault at all. I'm not sure what the next step would be, though.
Ah ok, would it be something along the lines of this, then?
We wish to show that (|x-y|+|y|)^\alpha \leq |x-y|^\alpha +|y|^\alpha \quad \alpha\in (0,1]. This is equivalent to showing (a+b)^\alpha \leq a^\alpha + b^\alpha \quad a,b &gt;0, \alpha\in (0,1].
We want to show now that the derivative of the LHS is smaller than the derivative of the RHS on (0,1].
Differentiating both sides WRT alpha yields:
\alpha (a+b)^{\alpha -1} \ ? \ \alpha (a^{\alpha - 1} + b^{\alpha - 1})
(a+b)^{\alpha -1} \ ? \ a^{\alpha - 1} + b^{\alpha - 1}
Where ? represents the relation to be determined. Now \alpha - 1 &lt;0. Therefore,
1 \ ? \ (\frac{a}{a+b})^{\alpha - 1} + (\frac{b}{a+b})^{\alpha - 1}
1 \ ? \ (\frac{a+b}{a})^{1-\alpha} + (\frac{a+b}{b})^{1 - \alpha}
1 \ ? \ (1+ \frac{b}{a})^{1-\alpha} + (1 + \frac{a}{b})^{1 - \alpha}
Therefore ? = &lt; for \alpha\in (0,1).
Does this seem right?
I don't think a derivative is going to help us here. We used it before to show if a \leq b, then f(a) \leq f(b). Derivatives involve functions, in that case we considered f(x) = x^{\alpha} where x was a positive real number and \alpha \in (0,1].
I'm a little bit stumped right now so I did a bit of searching and found this http://en.wikipedia.org/wiki/Subadditivity . This would help in our case but I doubt this is what is required how to solve this. I'm currently stumped, hopefully someone else can chime in, sorry! I'll think about it some more in the mean time!
Edit: Woops. Derivatives would actually be \ln[a+b](a+b)^\alpha and \ln[a]a^\alpha, \ln<b>b^\alpha</b>, which as you say would not be of much help.
Ok so a friend of mine proved it as follows:
Assume for the sake of contradiction that x\neq y and:
||x|^\alpha - |y|^\alpha |&gt;|x-y|^\alpha
\Leftrightarrow ||x|^\alpha - |y|^\alpha |^{1/ \alpha} &gt;|x-y|
Taking limits as alpha -> 0 from above:
0=\lim_{\alpha \rightarrow 0^+} ||x|^\alpha - |y|^\alpha |^{1/ \alpha} &gt;|x-y|&gt;0 \qquad \blacksquare
