Prove equation in Green's function.
4 replies · 3K views
yungman
Green's function [itex]G(x_0,y_0,x,y) =v(x_0,y_0,x,y) + h(x_0,y_0,x,y)[/itex] in a region [itex]\Omega \hbox { with boundary } \Gamma[/itex]. Also [itex]v(x_0,y_0,x,y) = -h(x_0,y_0,x,y)[/itex] on boundary [itex]\Gamma[/itex] and both [itex]v(x_0,y_0,x,y) \hbox { and }h(x_0,y_0,x,y)[/itex] are harmonic function in [itex]\Omega[/itex]
[tex]v=\frac{1}{2}ln[(x-x_0)^2 + (y-y_0)^2][/tex]
Let u be continuous and h is harmonic on an open disk around [itex](x_0,y_0)[/itex] in [itex]\Omega[/itex]. Show that
[tex]_r\stackrel{lim}{\rightarrow}_0 \int_{C_r} u\frac{\partial h}{\partial n} ds = 0[/tex]
Hint from the book: Both |u| and [itex]|\frac{\partial h}{\partial n}|[/itex] are bounded near [itex](x_0,y_0)[/itex], say by M. If [itex]I_r[/itex] denotes the integral in question, then [itex]|I_r| \leq 2\pi M r \rightarrow 0 \hbox { as } r\rightarrow 0[/itex]
Green's 1st identity:
[tex]\int _{\Omega} ( u\nabla^2 h + \nabla u \cdot \nabla h ) dx dy = \int_{\Gamma} u \frac{\partial h}{\partial n} ds[/tex]
[tex]h=-v \hbox { on } \Gamma \Rightarrow\; \int _{\Omega} ( u\nabla^2 h + \nabla u \cdot \nabla h ) dx dy = -\int_{\Gamma} u \frac{\partial v}{\partial n} ds = -\int_{\Gamma} u \frac{1}{r} ds = -\int^{2\pi}_{0} u d\theta[/tex]
h is harmonic in [itex]\Omega\;\Rightarrow \nabla^2 h = 0[/itex]
[tex]\Rightarrow\; \int _{\Omega} \nabla u \cdot \nabla h \; dx dy = -\int^{2\pi}_{0} u d\theta[/tex]
I really don't know how to continue, please help.
h = -v on Γ. You're not integrating over Γ; you're integrating around a small circle Cr around (x0, y0). You haven't said what h is, but by the hint, presumably ∂h/∂n is bounded on some disk centered at (x0, y0). This is certainly not true if h = -v on this disk, as ∂v/∂n = 1/r is not bounded. If h has no singularity at (x0, y0), then certainly ∂h/∂n is bounded on such a disk, as h has a continuous derivative (since by assumption h is harmonic).
Apply the hint.
Apply the hint.
Thanks for you help, let me try this:
So [itex]|u| \hbox { and } |\frac{\partial h}{\partial n}|\; \leq\; M[/itex]. As [itex](x,y)\rightarrow\;(x_0,y_0)[/itex]
[tex]_r\stackrel{lim}{\rightarrow}_0 \int_{C_r} u\frac{\partial h}{\partial n} ds = \;^+_- M^2\; \int^{2\pi}_{0} r\;d\theta \;=\; _r\stackrel{lim}{\rightarrow}_0 \; (2\pi M^2r) \;=\; 0[/tex]
I have [itex]M^2 \hbox { because } u\frac{\partial h}{\partial n} \leq M^2[/itex]
Yes. Now you have to prove that both |u| and |∂h/∂n| are bounded near that point.
Thanks for your time. But I got M^2 instead of M. It does not matter because r goes to zero.
